Time
DetFan
2,029
121
Livonia, Michigan
Can anyone tell me if its possible to change the time manually on my HR21?
I just noticed its an hour behind, and it is set for the right time zone.
I was told/read that they are supposedly going to address time issues in a firmware update. I was also told that if you change to another time zone, back out, then go back and reset back to the the correct time zone, that will force it to update to correct time. YMMV.
Its set on the right time zone, the time is off still
Run thru the set up menu and select a different Time Zone, go thru the process and then when it changes to the wrong time zone officially, go back and run it again and set it for your correct TZ and it should take care of it .... don't forget to do the last reset.
good luck, otherwise wait for D* to address it with an update.
Jimbo
HTL HD Questions
HR20-700 FX-HD recording problem
