tx code 21
mikeroberson2006
69
I have a service call with a description of tx code 21. I believe this code just means the transmit needs peaked and acp ran again?
This condition occurs when the transmitter fails a transmit pointing test. This indicates that the transmitter did not meet the minimum specifications required. This is likely due to an antenna installation problem. The antenna installer needs to fine-point the antenna. The transmitter will not transmit until the transmit pointing test passes.
Click here to re-run the transmit pointing test. Make sure that the weather is clear before running the test.
Trying to find a list of the tx/rx codes on the installation portal but cannot find them. Anyone know where they are or have a link to get them..........
Verizon DSL price
Wild Blue Install Help
