Uniden slave
mtullochreid
Dec 28, 2005
3
Hi..I have a Uniden Supra and Pansat 2500.
Does making the Uniden " the slave" , mean that it will respond to movement commands from the Pansat 2500 ( like the V-box II )
If so, can you tell me what connections I need to make - the Supra has two LNB input connections - Ku and C .
thanks !
Shawn95GT
Tivo fanatic
2,278
Phoenix, AZ
Unfortunatly, no :(.
What it means is that the 'IF out' will supply whatever source & polarity you have the Pansat tuned to to the slaved receiver.
mtullochreid
Dec 28, 2005
3
thanks for the info...I guess that means that the servo connections should go to Pansat receiver, and not the Uniden..
Would it be better if the Pansat was made the slave ?
Mr Tony
3,892
16,982
Mankato, MN
if you are mainly working with C-band, the Pansat should be the slave...but if you are a KU only, make the Pansat the master and the uniden the slaved unit :)
mtullochreid
Dec 28, 2005
3
Thanks for the help guys.
one last question - would it be okay to have dual imput connections to the servo - from both the Pansat and the Uniden ( but not simultaneously )..or would it mess up the servo ?
Signal Loss
Hello: I'm new here; looking for FTA Info in CT
