Wescopc, Interesting You mention, "through a switch"? What is the switch path to the LNBF?
The STB outputs 13.2Vdc, but had to override and manually push 18Vdc to the LNBF via the meter override to update the receiver. Also noted that the STB 22KHz signal is ON, but when signal is lost, the 22KHz cycles ON/OFF. Once it updated, am able to watch channels using a standard LO 10750 LNBF with no 18Vdc override.
I was told that the LNBF is not an off the shelf device. Guess we will know more in a few days...
