LNB and Diseqc switchs low level information needed
thelinuxer
12
Hey guys,
I was asked to make a presentation about satellite TV and how it works. I now have all the high level information I need for the presentation, but I need some low level information about the electronics of LNBs and Diseqc switchs (I thought that this is easy, but I had no luck finding those).
Can anyone guide me where to find block diagrams and/or schematics of these devices ?
Thanx in advace
Hey guys,
Thanx in advace
h ttp://www.sadoun.com/Sat/Products/Dishnetwork/LNBF/dpptwin.pdf
h ttp://www.satsig.net/lnb/explanation-description-lnb.htm
h ttp://www.scatmag.com/technical/techarticle-mar05.pdf
h ttp://www.isat.info/eng/share/index.php?db=share&category=LNB/Feed-Horn&mode=view&sp=0&id=151
h ttp://www.isat.info/eng/share/index.php?db=share&category=LNB/Feed-Horn&mode=view&sp=0&id=113
h ttp://www.st.com/stonline/products/literature/ds/10979.pdf
Must sign in Mytheatre forum;
h ttp://board.mytheatre.ru/dload.php?action=file&file_id=187
additional info
diseqc switch/command information:
h ttp://www.tech-faq.com/diseqc.shtml
thelinuxer I know what your looking for, it does exist I've seen it about 4 years ago on the web. Its the technical white paper that shows the programming, signal levels and frequencies. Try st.com and search on diseqc, they have alot of that type of info as they are the manufacturer of the diseqc microcontrollers for the motors and switches. Best of luck to ya.
Thanx to all of you guys. I checked out the links, but I can't find something that explains how the diseqc works. Can anyone explain it to me ? I want the low level -geeky - engineering talk :)
thanx again
Sg-2100 motor & Coolsat 6000 premium issues
Sadoun PowerTech DG280
