I keep getting the error No disk connect As on my
AZboxHD premium.Do anyone know what this means
and how to fix it?It will not boot just the same message on
the VFD front panel.
I have two premium receivers.I took the memory module outI think this is referring to your application area or the flash drive. This is a plug-in module. It appears that it cannot be found or its contents are corrupted.
You might try powering the box fully OFF and opening it and reseating the flash drive connection. If that is of no help, try updating the firmware or reformatting the flash drive (FORMAT APPLICATION AREA). Instructions are in a STICKY post.
I sure hope that something here repairs the problem and the flash drive is still good..
RADAR
Are you saying the Unit "A" will not boot with the Module from Unit "B", and "B" will boot using either Module?
Check all cable connections inside the unit, unplugged of course.
The AZBox units are known to have a cable or two pop off during shipping.
No all i did was power it on yesterday and it would not boot up.Did you do anything to it that it needed to be re-booted? Firmware / Channel List.
