AZbox Premium boot error
$905.00
wildboys
328
I keep getting the error No disk connect As on my
AZboxHD premium.Do anyone know what this means
and how to fix it?It will not boot just the same message on
the VFD front panel.
I think this is referring to your application area or the flash drive. This is a plug-in module. It appears that it cannot be found or its contents are corrupted.
You might try powering the box fully OFF and opening it and reseating the flash drive connection. If that is of no help, try updating the firmware or reformatting the flash drive (FORMAT APPLICATION AREA). Instructions are in a STICKY post.
I sure hope that something here repairs the problem and the flash drive is still good..
RADAR
RADAR
I have two premium receivers.I took the memory module out
of the one that will not boot up and placed it in my other unit.My second receiver boots up with the memory module from the premium receiver that won't boot up.I switched the memory modules still same error.I tried to boot to usb drive with firmware on it but still get the same error message.It isn't looking
good.
Are you saying the Unit "A" will not boot with the Module from Unit "B", and "B" will boot using either Module?
Check all cable connections inside the unit, unplugged of course.
The AZBox units are known to have a cable or two pop off during shipping.
Yes that is what i am saying.I checked all cables they are all
tight.I have had the box for at least 5 months so it is not a shipping problem.
The box was working the day before.
Wildboys,
Does the error state "NO DISK CONNECT AS" or "NO DISK CONNECT" or something a little different? I wanted to be certain of what you see precisely, as it may provide more clues. Also, what do you see prior to this, if anything? It might be benficial if we determine what step in the boot sequence this appears.
RADAR
H264 HD 4:2:2 video is not supported
SAFE TO REMOVE USB DEVICE
