Concrete Pad
PopcornNMore
3,635
128
Gibsonia, PA
As most of you know during the summer I poured a concrete pad to support my 8' WSI dish. I know that with a motorized dish it is critical that the pole be level to receive the various satellites, but how critical is it for the concrete pad to be perfectly level for a stationary dish?
When I poured the concrete pad I leveled it using a 2x4 as well as a trowel. Due to variations in the concrete (small bumps, etc) the pad is near level, but not perfect. When aimed at Galaxy 17 I never had a problem receiving the channels with a high signal strength. The elevation bar is simply adjusted for any variation in levelness. However, now when trying to receive the AMC 3 satellite (DVB-S2 channels) I believe I might need to shim the base to make it 100% level in order to receive the highest signal strength. Is this true?
I don't think so . For a single satellite, a plumb pole is not as necessary. You should have all the adjustment you need ( within reason) with elevation, azimuth and skew to bring in any sat that you can see !
I wouldn't think that the base that you're rotating the dish upon (azimuth) would make any difference as you also adjust elevation and skew separately. These are all automatic on a (properly installed) polar mount, making a plumb pole imperative.
If you motorize the dish on your pad, then you must ensure that it is level. But, for a single fixed point dish, you should be close enough and any errors in plumb you should be able to fudge around easily. I don't imagine that your pad is grossly unlevel.
RADAR
Some pictures would be nice to look at the progression from start to finish. Someday, I will move up to the big boys with an BUD for C-Band.
...Someday, I will move up to the big boys with an BUD for C-Band.
That was my feeling a couple years back. Now I have a basement full of BUDs. Get yours while they're hot ! (They are beginning to disappear from the landscape and can be still had for very little cash, or for free).
I removed the shims tonight that I had placed under the base last week to level and AMC3 now comes in better than ever.
:eek: My wife will never allow that dream!!!...
Do you store them on shelves, in containers or...??? Perhaps in one piece??? :rolleyes:
Got 2x4s on the floor, all are in quarters, the reflector segments are lined up in a row, sort of looks like a library of BUDs.
One piece? I have 10' ceilings, could put one together in the dining room one day, then invite the neighbors over...
Funniest thing I have heard so far today.
Fibre LNB's
