4DTV battery replacement.
coinmaster32
916
14
USA
What you are looking at is perhaps the most redneck 4DTV battery replacement.
I thought the battery just sat in the two prongs, held in by a dab of solder.
Well come to find out, the battery had the prongs on it originally.
Then come to find out, you CAN'T heat lithium batteries.
So like an idiot, I ordered just a standard 1/2AA and one without leads like I should of.
The when I found out I could not heat it, I had to put wires on it somehow, so I ductape them on there tightly and used a zip tie to secure them on.
I then soldered the wires to the prong and one solder terminal, and took some silicone to secure it into place.
I took a voltmeter and had 4.04 volts going to the solder tab, and the prong, so I knew I was good to go.
I also made sure the VC2 cage could clear it.
I hope you plan on putting a cover on that thing! :eek:
This idiot bought the lithium cell that fits into a AA battery holder and soldered the holder wires in! ;)
Did you receive the front panel I sent you??? :confused:
LOL WOW!!!!!
As long as it works :)
I've soldiered to lithium batteries before. Ruff up the surfaces then solider, never had a problem.
Me too never had a problem either but I don't mess around and take all day.
I have read instructions for replacing the battery, just wondering if you had the correct battery, I think you can get them with leads on them, couldn't you just solder the new wires to the old ones, then just cut out the old batter? This way you would not have to unsolder the wires from the board and take the chance of messing up the board.
Terry
Old Battery Tabs
Old battery tabs are " Welded " to battery they cannot be removed until battery is out of reciever. You can buy new batteries with either wire leads or tabs pre-welded to it. But those leads or tabs don't just line up an plug into right spot on motherboard you need something with flexibility of attachment. You have to attach either wires or other attachment method to connect/bridge to motherboard holes (those holes are small) from new battery.
A length of wire soldered to battery lead/tab gives you some flexibility in attachment point option on motherboard end such as old tabs removed from old battery and soldered to your new wires attached to new battery, or another homemade wire end of some type. There is a fair bit of advance preparation but not much actual time doing.
http://www.satelliteguys.us/attachment.php?attachmentid=62148&d=1298852197
7ninty's Albums
And you have to maintain constant power to motherboard battery area, by either (1) putting new battery in parallel briefly, but this has potential to damage or explode battery, or (2) by leaving receiver plugged and totally removing old battery first, but this has usual dangers of electricution of your "self" or other short circuiting danger to receiver.
But the Duct Tape, tie strap, silicone, hot glue, wire, etc method appears to work, and may last remainder of these receivers usability as well !!!
It says on the side "Do not heat above 212f" Did not wanna take any chances, I've seen lithium's explode, not a pretty sight.
Trying to set a 6 Foot dish at 99c
6ft or 8ft
