I still think lowering the dish abit is a good choice!Just pay attention while running your deere.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
From a close look at your grid, I'd say it's aligned excellent with the face of the dish.
Yes, the scalar ring is way off parallel to the dish face.
But, the LNBF is not as far off being perpendicular to the dish.
Worst point is, the LNBF is neither located-at, nor aimed-at the center of the dish.
Zoom in on the picture, and you'll see what I mean.
And people wonder why I always request photos...
I know it'll be hard to get the LNBF relocated properly, prior to lowering the dish.
I'd be inclined to suggest you wait 'till ya cut the pole, 'cause everything will be much closer to the ground.
Just be sure you don't cut off too much.
Once the LNBF is centered-on, and aimed-at the middle of your dish, I suspect you'll find you need to adjust the elevation just a wee bit.
But, that could be just what the doctor ordered.
Is there any chance you'll be able to look up through the hole in the center of the dish to see if the LNBF is centered?
I won't suggest rigging up a cheap laser pointer at this point, since it might be more like the tail wagging the dog.
But whatever techniques you develop for this little dish, will go a long way to ease the alignment of your big BUD, later down the line!
Dee I know you dont want to believe some folks advice, but for fun today (since it is pretty nice out) I put out the ghetto move 6 footer. Same dish (well pretty much. Mine is multi-colored due to changing some panels on it) and aimed for 99W to verify the post you made before about Live Well
Then moved the dish to 87W. Now for me in Minnesota 87-101 is all about the same elevation so I can literally move the dish across the arc. Moved to 87W and peaked the LNB a little bit (skewed it). I was goign to take pics of the setup but then I thought "she has a Coolsat" so hooked up the Coolsat 5000 to the dish
pics of ThisTV, MeTV, NASA and a couple other TP's to show something....63-64 is threshold on the Coolsat. 69-70 is very stable and 72+ is good
the dish will work fine for 87W
the receiver is a great machine
if you tweak it ever so slightly signal will move
I had to manually enter the info for ThisTV. Blind scan WILL NOT get it for some reason. Tried 3 times. 2 on "normal" scan and 1 on "detail"
But also as noted the scaler ring looks a smidge off. Try and make it level as that will help. If the LNB isn't 100% level dont worry as I know mine isnt yet I got results below.
Dee_Ann said:So my dad came by this morning with his pipe saw.
I didn't get any pictures because I had to help. Both of us lifted the dish off the pole and set it down then dad cut the pole off and I held the top part so it didn't fall and hit him in the head.
One thing I was concerned about was cutting the pole straight so that the part sitting in it would have a level surface to rotate on, if that makes any sense. So I took an old plastic coffee can, cut the bottom out and slid it over the pole. I took a white paint marker and drew a line using the edge of the can as a guide. Then Dad sawed the pole along the line and the edge came out perfectly level with the ground.
I have to toot my own horn and proclaim that I feel that was pretty darn clever of me..
So anyway, after he cut the pole we put the dish back on the pole and dad left. I took my little tv / pyramid / tripod invention and re-found the satellite again.
I didn't try to mess with the lnb or anything else just yet. Now that the dish is much lower to the ground, I can just stand on my tip-toes and touch the scaler ring. I'm going to take some cinder blocks and some boards and build a little platform that I can stand on to work on it, that way I can do away with the ladder completely and be 100% safe now with no risk of falling. I can leave the platform there as long as I need it.
I also purchased a little LED lamp with straps that you put on your forehead so I can see what I'm doing, considering I do so much of this in the wee hours of the morning. It's very, very common for me to be out back at 3am on the ladder messing with the darn thing. Holding a flashlight in my teeth American Pickers style just wasn't getting it. So I got the little head lamp. It has various levels you can set, 4, 8 or all 18 LEDs. Very handy! I like it a lot!
In a few weeks I'll have that little handheld tuner/meter thing in and that will help too.
But for now I think that with the dish lower and my little tv on a tripod, I can get this thing fixed. I'm sure now that all my problem is to do with the scaler ring being all wonky and the lnb off center and who know what else. But I'm sure it's all about the lnb area...
While I have worked with C-Band for 4 years now I was green when I first started with it so I understand. This was more of a "picture is worth a 1000 words" to show that the 6 footer does work fine for the 2 stations you really want (unless you want NASA too). My dish is not motorized, its "ghetto moved" which means just that. It sits in the garage and I wheel it out with the 2 wheeler in front of the garage (have line of site there) and literally pull the dish across the arc. I take the receiver (GeosatPro 200 or Pansat 1500) and find a known transponder. Bring that up and move the dish until I get quality. Then fine tune from there. Here in Minneapolis 93W is my true south (highest satellite in sky). From 87 over to 101 or 103 the elevation is very minimal change so I can literally slide the dish across the arc. For me to find 87W I dial up the Nasa transponder and go from there. Now I dont know if you are going to use this as motorized or fixed right now (some of your posts remind me of talking to my mother...they go so many different ways I forget what was said)WOW! Well, that's reassuring..
Of course you are obviously much more skilled at this than I could ever hope to be so you're much better at all the little tricks of fine tuning these things. I totally believe you and everyone else, that this can be done. I openly admit that I am completely unskilled at this and have no real clue what I'm doing. I am totally learning as I go on this and it's pretty difficult stuff, at least for me. Some of it I understand, some of it I will never understand. And being that I am mathematically challenged, that makes it really difficult if not impossible for me to deal with things like working out the arc stuff and what-not.
glad to help.Thank you for showing me that not only can it work but that it can work well. This inspires me to work harder to get this thing right!
Dee can shoot it with her iPhone, and by the time it's done, probably uplink it herself!Wonder if we could make a low budget movie to highlight your struggles and the reward for those struggles, it could air on PBS and we can all watch it with our FTA setups LOL!!!
so you are very close. We're talking a little move and you should get up to the 76 or so I showed. A thought is to lean into the dish while having the manual scan option up. If you lean into the dish and the signal goes up, then you know to move it a little bit. If it drops then try the other way to pinpoint the "sweet spot". If the signal drops when yo go East or West then try up or down. Very minimal changes can make a HUGE differenceI also found that now my MeTV is coming in very solid and clear. The signal is still only showing about 67% - 69% tops but it's steady and solid.
The reason is because of the FEC (Forward Error Correction)..basically how much of the stream is used to correct errors. The FEC is 5/6 for ThisTV and only 3/4 for MeTV.So I tried a manual scan for the thisTV channel and it ~A-L-M-O-S-T~ sorta wants to read it but it just doesn't quite catch. I'm only getting 64% on that transponder but it is in green at least. So I feel that I'm close.
As a point of reference, could you duplicate just this final picture you posted before?
It's the one with the dish horizontal, and the grid overlay.
Comparing the two side by side, would make great training aid for newbies. - :up
Absolutely ! . - :up
I only meant: sometime in the next few days.
And of course, assuming you were now getting all your signals, and the alignment looked much better.
By the way, your night photography is outstanding!
I think I saw what looked like a street lite up in one of your trees (pix of man up there to cut limb).
Didn't think ya had a flash good enough to lite up those dishes on the iPhone.!.![]()
Dee_Ann said:Shifting my hours a little towards normal, for a few weeks anyway... Oh the joys of sleeping disorders...
So.. I went out today into the daylight and didn't burst into flames or turn to dust as I was warned about!
I built a little platform out of cinder blocks and boards that I can stand on and work on the lnb without any danger of falling.. Whew!
I decided to see if I could try to dewonkify the wonky scarler ring.
