What would be nice is, where the signal button is, to add so you can bump the dish when needed.
This would be possible, but without a save feature.
I created a new satellite list as suggested. With no transponders in the new list I did a detailed scan of all satellites begining with 55.5W C-band. After five hours the scan was completed. It skipped all the KU sats or didn't find anything. One position has a KU sat only. During the scan it moved to that position but never reported any KU band info. Scan performance on the C-Band side was less than satisfactory, missing several channels. I scanned KU sats individually afterwards and had good results. My efforts to improve the multi-sat scan have made it worseSorry.... This timer and sequence cannot be user modified.
Why not make your own satellite list and as an example, arrange your KU satellites in order from East to West and the C satellites West to East or place the C and KU satellites side by side in the list?
NBC West on C-Band is freezing/glitching. All other NBC's are fine as well as any other channel I have viewed. What is so special about this one?
I am not able to drive my dish motor through the VBox using the East/West buttons in the Switch/Motor menu. The motor is set to DiSEqC. Has anyone else tried to use this feature? Similarly the VBox will not respond to "Go to X" when changing to a saved satellite position. Thanks
Thanks for the feedback. Perhaps its with my set up as the VBox is located about 30' away and maybe the distance is causing the DiSEqC pulse to become distorted and unreadable by the VBox.
