it scans in with the solomend s9. info says it is 1080i and h264 and ac3. this is on the 6'. will scan it in with the microhd when the wife lets me use the main tv. charlie
Just went to Ali editor and it shows it as mpeg2...no way I can see to change to H.264, looks like when you scan a channel it defaults to whatever. So I'm more confused..perhaps Brian can shed light on how to do this?
In the AliEditor folder open the AliEditor Configuration Settings file and change: Chip Type=M3601s . Save the file then change the file to read only. This should keep the AliEditor software in the correct mode to provide advanced settings.
Good signal but no audio or video. Manual PID scan had same result on both my Pansat 9200 and the Coolsat 8000.All the others on this transponder play fine.
UPDATE: Deleted everything on 99w in the Pansat 9200 & did a fresh blind scan and the new NBC in HD is there with the others and playing fine!
So for others having trouble, a fresh re-scan may do the trick!![]()
joeroscoe1957 said:Did as you mentioned on my pansat 9200 , all pr mux ch's now there , but just audio for nbc (which is now on tv3 instead of tv4) but no video , other ch's work fine ?? Did you change any scan settings ? I do not have a dvb s-2 board , but do not think it applies here .
Iceberg said:ironically Dish uplinked the ABC & NBC (in HD) now for Puerto Rico subs (not available yet)
CBS is from that "lovely"WSEE in Erie
No fox yet in HD...but maybe soon?
Oh and before someone says it...no the uplinking of these in HD will not affect us seeing them right now. Dish has had them in SD for a while now (using the same feed as we get)![]()
