Ok guys, a first time poster here, I have been reading for several weeks now and Direct TV hasn't been able to help me. I use Direct TV at the house for a couple of years now and have been happy with it. We spend several months a year on our boat and the family has been asking to get some type of TV on the boat as well. I haven't really wanted to spend the money just for TV but my Dad's neighbor upgraded his system on his boat and gave me a KVH Tracvision HP4 system. It had three boxes with it and a cablemaster multiswitch. one of my family members brought it to me but he had the cable boxes in the back of the vehicle and they got wet. They are trashed and do not power up.
I called Direct TV and they said that we should be able to use the boxes in our house adn just take them to the boat when we go. I have been attempting to bench test them by setting everything up in the driveway and making certain that we can get everything working prior to installing on boat.
Upon powering up the KVH dish it seems to go thru a startup sequence and seems to find the satellite. I have tested rotating the antenna and it will track regardless of angle. I have the install manual for the KVH system and it seems to be straight forward. With everything hooked up the cable box go thru a start up process and then gives me an error 775. I have done research on here giving the the answer to the 775 issue and it appears the the cable box is not communicating to the antenna.
I have spoken to Direct TV letting them know that the KVH system is not High Def and that all my boxes from the house are high def. They have told me it still should work. I feel that it may be an issue with the multi-switch or an incompatibility with the cable boxes and the antenna. My Dad told the system was working so I believe the antenna works OK but haven't tested that out.
So I am at a loss. I have attached a diagram from the KVH manual and the cable boxes in the house are model H25-700. I hooked one of the H25s up to an output port on the CableMaster multi-switch as shown in the attached diagram. I played with it all day yesterday to no avail. Had the multi-meter out testing voltage on the antenna and multi-switch trying to the forum here for advice.
Any help is appreciated and I can provide more pictures/info if needed. Thanks.
to Satelliteguys mrdeepseafisher!
