Declination Angle
  • WELCOME TO THE NEW SERVER!
Ali Erfani
13
5
Turkey
Another equation for figuring your declination angle, instead of using less accurate tables.
Ali
Reactions: KE4EST
The earth is not a perfect sphere. Therefore the radius and distance to the arc are variable depending on your location. You need to determine those two factors for the equation to work correctly.
Hey guys, some folks enjoy Math and like to use it solve their given problems.
That said, I agree with Shicks4, the tables get you close enough to start off with.
Plugging numbers into a formula or calculator isn't particularly stimulating. Mathematics is deriving the function that you plug the numbers into.
Reactions: a33
You're absolutely right, earth isn't sphere & earth radius is variable from equator to polar, if you want to get an accurate result you need to get your latitude radius & also distance to your desire SAT first before using this equation. I just put 3964 & 22300 values in order to write the equation & is not exact radius & distance to satellite for other site's.
Ali
You can get your site radius & distance to satellite through these equations.
Ali
I know calculation is a hard way to get all these information when you can get them in seconds on the net. but i'm a pilot & flight navigator and I have learned & accustomed to do every job on it's standard way instead of relying on the internet & website's. That's why i rather to solve such given problems through computations. Imagine you need to set up your satellite in the middle of desert with no internet connection, it's not better to do it yourself instead of getting help from other sources?
Ali
If you were launching satellites details like the exact radius of the Earth would be of interest, but we are talking about polarity (or even azimuth or elevation) that going to vary by numbers that are much smaller than the resolution of the instruments that are used to aim the dish. The worst-case scenario is that the radius number is off by 11km or 0.15%. The impact on the angle formula is a much smaller percentage yet.
If you think about it, this kind of variance could easily be undone by the sun passing from one side of the dish to the other and the thermal expansion of the materials changing where the dish is pointing.
