4K install and equipment question
cpd5215
108
8
Columbus, Ohio
Even if you don't have a Reverse Band capable LNB, the tech. is required to install one with all 4K upgrades
But for now, look on the HR44 for the LNB data in "System Info & Test" ----> "Genie info." under the receiver settings.
If you already have a Reverse Band LNB, then you should see "Reverse Band" listed next to a "RB/INTL" catagory.
The RB is for future-proofing as DIRECTV eventually plans to move all 4K programming there.
Ill take a look in a sec....actually on phone with DTV inquiring about 4K....she is telling me she can simply swap out C41 with a C61K without changing genies....IE HS17 or HR54.....and Ill get 4K.....wrong right??
mdram
4,082
810
Md
ad the c61k is wired vs wireless. so not that simple
add in the genie needs moved.
cs sometimes has 'issues'
Reactions: cpd5215
cpd5215
108
8
Columbus, Ohio
Actually looking now while on hold since I questioned her about her explanation of 4K....Next to RB/INTL, I see "None selected"....
cpd5215
108
8
Columbus, Ohio
So she comes back from talking to her boss and will offer me C61K with HR54 upgrade at no cost and is saying she is waiving the $7 box fee for C61k.....should I go for it?
mdram
4,082
810
Md
also note, you will most likely get a 2 year contract, and be stuck with this setup for that timeframe
DTV-Tech
40
6
Goldsboro, NC
... I'd avoid the HS17, get the 44 upgraded to the 54, and swap the C41 for the C61K. The RB3 is also no charge, and all of this should cost nothing (except the adding
of 4K content to your regular programming). Watch the tech when he swaps the lnb and make sure he performs the EIV test at the dish and YOU WANT TO SEE ALL
SEVEN CHECK MARKS on his AIM meter ... too many techs just hit and run ;)
cpd5215
108
8
Columbus, Ohio
Thanks a lot for that advice. I appreciate it.
Jimbo
71,056
9,565
NW Ohio - Buckeye Country
Or you can just let him do his job ...
You are not going to see the 7 check marks on his meter and you don't know what they mean anyways.
Just check your recvr numbers on the HR54 when the swap is done.
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
33,157
18,482
Cheshire CT
There isn't any charge for 4k, not yet anyways.
Reactions: Jimbo and cpd5215
moving satlite from roof mount to wall mount.
Why does Whole Home not work on my setup???
