Testing the Titanium C140 and C240 5G Filtered BLUE LNBFs
N6BY
Geek
3,380
3,421
Roseville, CA 121W
I recently received the new C140 and C240 5G filtered BLUE LNBFs from Titanium Satellite https://titaniumsatellite.com/products.php
The C140 has one output and the C240 has two. The pass band for both LNBFs is from 4,000 to 4,200 MHz. Most North American satellites have moved all of their transponders to this 200 MHz frequency range, with the exception of 115W and 117W which are intended for Mexico.
This first signal graph is from an older LNBF that has a pass band of 3,800 to 4,200 MHz. As you can see, the 5G signal spikes at my QTH are quite strong!
The signal graph below is from the new Titanium C140 LNBF, taken from the same dish and the same satellite as above. It filters 5G very well below 4,000 MHz.
Graphs are useful, but the most important consideration is how well do these LNBFs perform with actual FTA TV viewing? I scanned each satellite from 103W to 139W and I didn't see any reception glitches.
When mounting these LNBFs, the "0" mark on the back should be adjusted so that it is horizontal (parallel to the horizon).
The LNBF package includes a scalar ring, 7 mounting screws, an allen wrench, a dielectric slab for circular polarity reception, and an installation guide with specifications.
The photo below compares the size of the C140 (in front) with the older C138. You can see that the C140 has a larger circuit board container, which is very well sealed to prevent moisture intrusion.
In summary, I am very pleased with the performance of these 2 new LNBFs. If you are experiencing any 5G interference in your C-Band reception, I highly recommend the Titanium C140 and C240 LNBFs.
Aside from differences in frequency filtering, how does the signal strength from 4000-4200 MHz compare between the C138 and C140? If I'm understanding the graphs correct, the C140 looks like it has better signal?
They are about the same signal strength. But I can see how you would think the C140 has higher peaks --- the vertical scale of the graphs are different (5 dB vs 10 dB on the left side).
Reactions: FTA4PA
Brian's blue lnbf came today. It works great. The 3.8 to 4.2 lnbf in the last few months became unwatchable on several feeds as the last of the 5g got turned on in September. The new 4.0 to 4.2 dual is fantastic. Hope it works great for everyone.
I hope it works Eutelsat 117 West freq 3947 as my Wife can't watch the Honduras Channels anymore. Will give a try in January
Reactions: FTA4PA and MikeI
A transponder at 3947 MHz is far below the band pass frequency range of 4000 - 4200 MHz and will not be received. The C140 and C240 BLUE filter LNBFs attenuate all signals outside the band pass. Simply put: you cannot filter out the frequency that you wish to receive. Save your money, aggrevation, dissappointment and a pending bad product review! 😯
Your best chance of receiving the 3947 transponder is to locate a 3900 - 4200 BPF LNBF.
AND
Block the 5G terrestrial signals from reaching your dish. You might have to move the dish behind a structure or build a rf wall out of chicken wire / hardware cloth, etc.
It is extremely helpful to use a 3700 or 3800 - 4200 BPF LNBF with a spectrum display, to view the 5G interfering signal spikes that would be present below 3980 MHz. You will then see if attempts to block the terrestrial 5G signals are attenuating the spikes. An inexpensive tinySA Ultra purchased on Amaxon or Ebay along wthe a 2GHz splitter is all you need to identify the signals you wish to receive vs those you don't. Otherwise, your just playing an expensive game of "Pin the Tail on the Donkey" with labor and buying / trying various filters.
...It is extremely helpful to use a 3700 or 3800 - 4200 BPF LNBF with a spectrum display, to view the 5G interfering signal spikes that would be present below 3980 MHz. You will then see if attempts to block the terrestrial 5G signals are attenuating the spikes. An inexpensive tinySA Ultra purchased on Amaxon or Ebay along wthe a 2GHz splitter is all you need to identify the signals you wish to receive vs those you don't. Otherwise, your just playing an expensive game of "Pin the Tail on the Donkey" with labor and buying / trying various filters.
My first signal graph in post #1 is 117W with a 3800-4200 C138. 3947 is not receivable here with either the C138 or C140 -- there is simply too much 5G at my location. However, with the C140 I was able to receive as low as 3972 on 117W.
... If you don't want to buy a TinySA, there is currently a TBS6983 on eBay for only $49 !! (It's not mine, but it is a great deal). The seller lists it as a "Quad Tuner", but it is actually a dual tuner. Still, for the price it is well worth it. I use my TBS6983 with EBSPro and the EBSPro mobile app to fine tune my satellite dishes. Also used it, of course, to make the signal graphs in this thread.
Anyway, yupidixie, if you are somehow able to get 3947 I will be interested to know how you did it. Before I got a C138 I tried blocking 5G with wire mesh, but it turned out to be a futile effort and a waste of $100.
AND
Thank you for the advice.
AND
@ the red Highlighted: The Titanium C240, for some reason may have defied the odds as I'm able to scan, log and play the video without interference on Octagon SF8008, and TBS6903X. See attached screenshots.
Titanium Well, even though I am in the center of 3 cell towers, all of which are a minimum of 2.5 miles away, and 5g is pretty weak right here, I recently started getting just a bit of 5g pixelation on my satellite channels. Just enough to be really annoying. So, I bit the bullet, and just bought and received a Titanium C240 5g filtered LNBF today. I just finished installing it, AND, the results are GREAT!
Pixelation is gone, and no more issues. I also made sure it was installed and tweaked perfectly for my dish, and I even got a hair better signal from it, almost 2dB compared to the older C1-PLL Titanium NON 5g filtered LNBF.
Thanks Brian, I appreciate it!
I would be really interested to know if anyone has successfully used this method to block 5G signals. I see that it did not work for N6BY so I just wonder if it has worked for anyone.
What we really need is an LNB where the upper threshold of the lower filter is user-adjustable, so that you can set it to anything from 3.7GHz on up to somewhere near 4.2GHz Anything below where you set it would be blocked, anything above would be passed. Of course it would also filter 4.2GHz up, so the pass range would be wherever you set the lower limit to, up to 4.2GHz. So you could have 3.7-4.2, 3.8-4.2, 3.9-4.2, etc. but you could also have like 3.94-4.2. So you could tune it with (for example) a small screwdriver and try to find the "sweet spot" where the 5G interference disappears, leaving the channel you want.
Part of the reason for this is I have read that T-mobile uses 3.9GHz so if you are trying to get something on 3947 MHz and T-mobile's pumping out 5G on 3900 MHz, none of the fixed-bandpass filters I have seen would help, and also nobody wants to spend several hundred dollars on a filter that only works with the really old style LNB's and feedhorns and that only might work. I know we probably all have some old Chaparral feedhorns lying around but I really have no desire to go back to those clunky things, plus those are the ones that use that stupid mechanical polorotor to switch polarity (that always seems to die in the coldest part of winter).
FREE C-Band dishes in New Mexico
Tree Trimming ??
