OTHER GTMEDIA V7 or V9?
I beg to disagree. The GT Media boxes give more than you pay for. My goodness, I only paid $30 delivered to me for a V7S5X. I paid $215 for my Edision Mio+ (plus shipping). Which is best? I never answer that question about anything. Each has its own capabilities.
The GT Media has a rapid accurate blind scan. For this reason, I blind scan all the time: repeatedly each satellite, each day. The receiver is sensitive. Its streaming capability is pitiful. Its user interface is a little awkward but you get used to it. The Edision blind scan requires you to get food before starting so you don't perish while waiting. But...the Edision's streaming capability is excellent. The other features of the Edision make it a quality receiver worth its price provided you invest some time to learn it well.
I'm glad I have both boxes. I would buy either again without thinking further.
4.2.2.? I will never believe any consumer receiver will have that capability despite what its advertising may claim unless I see it for myself. For me, considering the rarity of 4.2.2. that I find, I can just stream the feeds wirelessly via wifi to my laptop and plug the HDMI cable back into the big screen. This is easy and works reliably.
Reactions: comfortably_numb
Check which firmware you have now. The latest is: V464_20231109
Just checked and there is a new firmware available for the V7S5X. v466_20241112 is the number but when I unzipped it and read the instructions it says to use Hungarian language??? Anyone installed this?
Just saying.................
Just checked and there is a new firmware available for the V7S5X. v466_20241112 is the number but when I unzipped it and read the instructions it says to use Hungarian language...
I haven't installed it. But I'm pretty cautious about messing with the firmware on these lower cost boxes. I'm nervous you may not be able to go back if the newer firmware doesn't work well. Are there any notes suggesting the new stuff will make it function better?
Just checked and there is a new firmware available for the V7S5X. v466_20241112...
You got me curious. I tried loading this firmware and got the message "upgrade failed". I tried a couple times using All Code and Main Code methods. So I tried the previous V465 version. Same results. I don't know if I'm doing it wrong or this firmware isn't compatible with my hardware.
cyber did you ever get that v465 version to load and work on your V7S5X again?
GEOSATpro microHD: No LNB Voltage Output
OTHER Motor movement behavior
