This agrees with feedback I see on the GT Media support site. It seems many are having issues with GTShare....Seems to be pretty buggy.
I had it working yesterday, can't today. Seems to be pretty buggy. I can't navigate the app very well.
That may be the reason for the glitch. My cable modem is 10 years old.Make sure the box is connected via ethernet; the built-in WIFI radio on the V9 can only do 2.4ghz. Video streaming requires a lot of bandwidth.
I only have wifi available. My main router is physically cabled to the Internet source. But I have no ethernet distribution in my house. It's all wireless. With 1 Gbps Internet service, this has always worked fine even if streaming multiple video sources simultaneously.Possibly. I tried using the built-in WIFI and got choppy video. Once I connected the V9 to ethernet and disabled WIFI, the video was a lot more smooth. Make sure your phone is connected to a 5Ghz WIFI network also.
cyberham the issue you're having looks like something on your gateway or router is blocking the port(s) the V9 and GTShare app are using to stream.
I didn't need to do anything special when implementing my Android app to use with my Edision receiver.
We are connected by ethernet cable from the modem. How do you know which band is connected?Possibly. I tried using the built-in WIFI and got choppy video. Once I connected the V9 to ethernet and disabled WIFI, the video was a lot more smooth. Make sure your phone is connected to a 5Ghz WIFI network also.
Not getting the speed I should. Should be getting 150 mbps. Only getting 80 on the phone. About 40 on an old kindle. I'm in the market for a new one now.If the router is 10 years old, you may only have 2.4Ghz WIFI. Some routers broadcast separate 2.4 and 5 SSID's (network names). If it's a mesh system (unlikely) it's more difficult to tell on your phone. Do a speed test from your phone near the router. Are you getting close to the upload/download speeds your're paying for?
You could try turning off the firewall on your router (if one is in use).
I suspect GT Media doesn't support 5 GHz
I meant the GT Media V9 Prime. I was thinking since it always seems to take a 2.4 GHz connection on my network, never 5 GHz.I'm not sure why it wouldn't, unless the Android app is different from the Apple one..
Usually in the Settings area there should be an internet/wifi option.Now it looks like my GT Media and phone are on the same network, on the same router. I have two wireless routers so I moved to the room so both are on the same router. But...my phone is on the 5 GHz system and the GT Media is on 2.4 GHz. I suspect GT Media doesn't support 5 GHz. But I don't know how to move my phone to the 2.4 GHz system, or whether I want to, or if it matters. Was life always this complicated?
I tried setting 3G, LTE and 5G without luck. I think these settings are to select the preferred mobile network. I always use 5G if available for mobile data. The settings don't affect whether the phone uses 2.4 GHz or 5 GHz for local wifi.Usually in the Settings area there should be an internet/wifi option. That what I use on my smart phone to switch from 2.4 to 5 ghz...
