P* Aiming...I'm Totally Lost
stogie5150
Crazed Cajun Rebel
3,841
88
Slidell,LA
Okay, I have the P* set up, tv and reciever (Coolsat 5k) by the dish. I am trying for G10 and am having no luck whatsoever. I set the elevation using my angle finder on the mount ( it matches up pretty good with the scale on the mount itself) I've gone from 180 degrees ( due south) to 90 degrees east without a sniff of signal. I've added a degree of inclination and did it again. Added two and did it again. Nothing. The dish itself skews, do I need to skew it? I'm not moving it a lot at a time, just a little I know it is touchy.
I have the reciever set on a Vertical transponder as I am using the Vertical side of the P* LNB.
I'll add some pics if need be. Thanks Y'all.
Here's my list
Code:
         Latitude 30° 18.567'N Longitude 89° 47.647'W
                      Sat Name Sat Lng Az(t) Az(m)   El  Skew
*** Of Particular Interest ***
                    EchoStar 3   61.5W 133.2 133.0 43.1 -39.0
                    EchoStar 6  110.0W 216.1 215.9 48.3  30.6
                    EchoStar 8  110.0W 216.1 215.9 48.3  30.6
                    EchoStar 7  119.0W 227.9 227.8 42.5  39.9
                    EchoStar 5  119.0W 227.9 227.8 42.5  39.9
         EchoStar 9/Telstar 13  121.0W 230.2 230.0 41.0  41.6
                    EchoStar 1  148.0W 252.6 252.5 18.8  55.5
                    EchoStar 2  148.0W 252.6 252.5 18.8  55.5
                    EchoStar 4  157.0W 258.0 257.9 11.0  57.6
                     DirecTV 3   81.8W 164.4 164.3 53.6 -13.4
                     DirecTV 2  100.8W 201.1 200.9 52.7  18.1
                    DirecTV 1R  100.8W 201.1 200.9 52.7  18.1
                     DirecTV 1  101.0W 201.4 201.3 52.6  18.4
                    DirecTV 4S  101.2W 201.8 201.6 52.5  18.7
                     DirecTV 6  109.8W 215.8 215.6 48.5  30.3
                     DirecTV 5  119.0W 227.9 227.8 42.5  39.9
*** All Satellites 61W - 160W ***
                     Rainbow 1   61.5W 133.2 133.0 43.1 -39.0
  Brasilsat A2 (incl. 5.8 deg)   63.0W 135.0 134.8 44.2 -37.6
                  Brasilsat B2   65.0W 137.5 137.4 45.5 -35.7
                  Brasilsat B1   70.0W 144.5 144.3 48.6 -30.1
                      Nahuel 1   71.8W 147.2 147.1 49.6 -27.9
                         AMC 6   72.0W 147.5 147.4 49.7 -27.6
                     Galaxy 12   74.0W 150.7 150.6 50.7 -25.0
                         SBS 6   74.0W 150.7 150.6 50.7 -25.0
                       GOES 12   75.0W 152.4 152.2 51.1 -23.6
                         AMC 5   79.0W 159.3 159.1 52.7 -17.8
                       Nimiq 2   82.0W 164.8 164.7 53.7 -13.1
                  Brasilsat B3   84.0W 168.6 168.5 54.1  -9.8
                       XM Roll   85.0W 170.6 170.4 54.3  -8.1
                         AMC 9   85.0W 170.6 170.4 54.3  -8.1
                         AMC 3   87.0W 174.5 174.3 54.5  -4.8
                      Galaxy 9   91.0W 182.4 182.2 54.6   2.1
                     Galaxy 11   91.0W 182.4 182.2 54.6   2.1
                       Nimiq 1   91.0W 182.4 182.2 54.6   2.1
                  Brasilsat B4   92.0W 184.4 184.2 54.6   3.8
                     Telstar 6   93.0W 186.3 186.2 54.5   5.5
     Galaxy 8I (incl. 1.0 deg)   95.0W 190.2 190.1 54.2   8.8
                     Galaxy 3C   95.0W 190.2 190.1 54.2   8.8
                     Telstar 5   97.0W 194.1 193.9 53.8  12.1
 Inmarsat 2 f2 (incl. 1.7 deg)   98.0W 195.9 195.8 53.5  13.7
                     Galaxy 4R   99.0W 197.8 197.6 53.3  15.3
                         AMC 4  101.0W 201.4 201.3 52.6  18.4
                        AMSC 1  101.1W 201.6 201.4 52.6  18.5
                         AMC 1  103.0W 204.9 204.8 51.8  21.3
 Solidaridad 1 (incl. 2.8 deg)  103.5W 205.8 205.6 51.6  22.1
                         AMC 2  105.0W 208.3 208.1 50.9  24.2
     G-Star 3 (incl. 11.5 deg)  105.0W 208.3 208.1 50.9  24.2
      G-Star 1 (incl. 6.0 deg)  105.0W 208.3 208.1 50.9  24.2
                        MSAT 1  106.5W 210.7 210.6 50.2  26.2
                       Anik F1  107.3W 212.0 211.8 49.8  27.2
                       Anik E1  109.2W 214.9 214.7 48.8  29.6
                      Anik E2R  111.1W 217.7 217.5 47.7  31.9
                 Solidaridad 2  113.0W 220.3 220.2 46.5  34.0
     Morelos 2 (incl. 4.4 deg)  114.9W 222.9 222.7 45.3  36.0
                       XM Rock  115.0W 223.0 222.8 45.2  36.1
                      SatMex 5  116.8W 225.3 225.1 44.0  37.8
                       Anik E2  118.7W 227.6 227.4 42.7  39.6
                    Galaxy 10R  123.0W 232.4 232.2 39.5  43.1
                      Galaxy 5  125.0W 234.4 234.3 38.0  44.6
                     Galaxy 12  125.0W 234.4 234.3 38.0  44.6
                     Galaxy 13  127.0W 236.4 236.2 36.5  46.0
                     Telstar 7  129.0W 238.3 238.1 34.9  47.2
                     Satcom C3  131.0W 240.0 239.9 33.2  48.4
                     Galaxy 1R  133.0W 241.8 241.6 31.6  49.5
                     Satcom C4  135.0W 243.4 243.2 29.9  50.5
                       GOES 10  135.5W 243.8 243.6 29.5  50.8
                         AMC 7  137.0W 245.0 244.8 28.3  51.5
                         AMC 8  139.0W 246.5 246.3 26.6  52.3
 Inmarsat 2 f3 (incl. 1.9 deg)  142.0W 248.6 248.5 24.0  53.5
        TDRS 9 (incl. 7.4 deg)  151.0W 254.5 254.3 16.2  56.3
       TDRS 10 (incl. 6.2 deg)  151.0W 254.5 254.3 16.2  56.3
       Satellite Finder is (c) Copyright 2004, P. Lutus
use the elevation scale on the dish. P* dishes are offset (usually) so you have to take that into consideration
Also the LNB needs to be skewed properly or it wont work. That skew seems like a lot. I'm at 93.5W and it is only about 30 skew for me.
If all else fails, try a blind scan. Scan all and see what pops up. I've had issues with the P* LNB's and found if skewed wrong, I got H when I needed V polarity so I got the H stuff on 127 (which is very strong)
I think I know what I am doing wrong, but I am not going to say until I try it. Let's just say I think I am looking at the wrong point in the sky. :eureka
Instead of turning the LNB could I just skew the whole dish? 90 is level, that would mean I would skew to 120 on the scale, correct?
does the dish skew? If it can, that is what I would do
if standing behind the dish, the left side of the dish would be higher
Think you need to be going west ?
Wyr
Here's my list
Code:
yeah you need to go west. :)
according to the list above, 232 is where you need to be
225 is SW so a smidge W off SW :)
Wyr
Exactly. I misunderstood the chart..I didn't understand that for my position I would need to point at MAGNETIC 232.2.
I am currently trying to aim at MAGNETIC 123.
I am embrassed to say the least. :shocked
Got something...just don't know what. Only have channels on Tp1, and they're all scrambled. I've looked and looked at the lyngsat charts and I don't see them anywhere...
The list:
1-skl1
2- daai
3- cqtv
4- csgd
ETC...
Where the heck am i?
so that was 127 so youre close
Sounds like you're just getting the H polarity stuff. I would go back to there, hook the cable ot the other output on the LNB and move it 4 degrees east and G10 should be there
Stogie you should get something without raising the dish, its only 4degrees..
But you're in the neighborhood now, once you hit the G10 you can raise it up a bit.
Once you see how touchy it is, it wont be so hard to find the next time. And mark the position on the pole with a marker or something too.
charles
I have 127 marked...and I raised the dish and moved again..no dice. adjusted the skew difference...nothing. Grrrrrr...
Hey I just looked back and saw that dual-lnb setup-if thats what you're using now, are you getting horiz and vertical from one lnb, or vert frm one and Horiz from the other?
That may make it harder to aim..
charles
No I have a single LNB arm I swapped it out with....just using one now...I snapped a couple of pics...the sun is in the way but here it is...I centered the camera in the dish and snapped this....this is about the best one...
Turbosat ( and me) think I might have a tree problem. :mad:
C-Band to 4x4 DTV Switch
Need help with new dish
