There are PPV Movies available in 1080P, check the 501 channels.
Those are not broadcasts however, they are pretty much the equivalent of streaming.
I think the H3 does 4 separate tuners in the "sports bar" mode. That would make sense, because it would leave 12 tuners to be spread across the max number of Joeys (6) which, if they all were 4k Joeys, can each do PIP, requiring 2 tuners feeding each. That way, every viewing location in the house (7 total) will be able to watch unique content, all at the same time. Pretty impressive!!OK, maybe I misread one of these H3 threads, but I thought I read that all 16 tuners could be viewed at once. I am guessing the only way to do that is if (1) the H3 is in sports mode taking up 6 tuners, and you have 5 4K Joeys all in PIP mode taking up the other 10.
No. It is 16 actual tunersis just 4 tunner, each tunner record up to 4 same transport channel?
I thought it was 20 with OTA?
I wonder if Molly B. is single.
I think that you will need 4K TV sets on those four locations to actually order four 4K Joeys. You could, of course buy your own....Scott, I'm planning on switching from directv back to dish once the H3 comes out. Since I'll need 4 joeys will I be able to request 4 4K joeys? Or will there be a limit I can get?
I have a question, I have a Hopper 1 now. If I get the Hopper 3, can I basically move the contents of the Hopper 1 to a external hard drive? Will a internal hd that is powered externally and connected with a IDE/SATA to USB 3.0 cable like this
http://www.newegg.com/Product/Produ...87zjFNud9i2Tl_73u-IAYaAjDQ8P8HAQ&gclsrc=aw.ds work for this purpose? And the external HDD or SSD will then connect to the Hopper 3 so I can access the content? Is there anyway to transfer the content back to the Hopper 3's internal HDD?
That feature is still in testing and may not be in the initial release. You don't have to copy your recordings from the EHD to the new Hopper. They can be played back from the EHD.I thought I read on one of these posts that you'll be able to connect your hopper3 to your older hopper (via Ethernet?) and transfer recordings directly. Rather than do the whole EHD upload/download steps. Am I delusional?
