3 Ports DiSEqC Switch with Temperature Sensor
wallyhts
Staff member
HERE TO HELP YOU!
3,218
442
Found this at CES.
What do you all think? Would anybody like to see the temperature on there STB?
Interesting concept. So many other devices around of now that show the temp.
Reactions: wallyhts
How does that display the temp via the STB?? "Return" Diseqc data, as far as I know, isn't implemented in any consumer DVB-S/S2 'box'.
And in all actuality, when it's this cold, (-17°F yesterday AM) I don't need reminders.
Reactions: wallyhts
DR-HD STB's support it. I have a hot cake model to try it.
Where and how does it display the detected temperature? Personally, I don't want more things in the signal path.
EDIT: O.K. That was answered. Had eye test this morning dilated eyes not seeing too good at the moment
Reactions: wallyhts
Own development of company Dr. HD! DiSEqC 3x1 with the built in thermode. The arrangement deduces in the menu of a receiver temperature behind a window.
Given digital ????? the sensor control works with receivers of ruler HotCake HD!
Protection against short circuit on a cable
The tight plastic body protecting from a rain and snows
High pass of a feed, up to 500 ??
3 port DiSEqC 1.1
Range of frequencies: 950-2400MHz
The Internet-connection is not required!
Description:
· Faster loading;
· Full compatibility DVB-S2 / S, MPEG-2, MPEG-4, AVC H.264;
· Ultra CAS card slot
· Support for external WiFi-adapter;
· Officially certified Crypton;
· Fast channel switching;
· Clear menu, easy setup and management;
· 2x USB 2.0
· PVR-ready - possibility to record on external USB-drives;
Multimedia Player: Audio - MP3, MP4, OGG and others., video - MKV, AVI, DIVX, etc., the graphics - JPEG, BMP and others; · Compact body, which if necessary can be mounted on vertical surfaces; ·
TV guide and TV shows for the week; · Power Supply 12V, allowing the device to work in the car, on the boat, in nature, etc; · Copying the software and settings from the receiver to another receiver by cable;
Ability to work with weather station Dr.HD;
Reactions: wallyhts
I've never seen -50C here, nor do I want to. However, according to one of the well known but unwritten laws of antennae theory, the colder and more miserable the weather is when you install or repair an antenna, the better it will work. Imagine how well their antennas work when they can install at -50!
Reactions: wallyhts
Yeah..How is did the test go?
