Audio settings help please
Building
180
I've got a PS3 hooked up to any Onkyo 505 with optical cable. I have the BD/DVD Audio Output Format (Optical Digital) set to Linear PCM. I have Dolby Digital 5.1 Ch. checked DTS 5.1 Ch. checked, and the Linear PCM 2 Ch. 44.1 kHz and Linear PCM 2 Ch. 48 kHz are grayed out and checked. Should I be checking some of these other choices like AAC?
Something must be wrong, because when I do a sound check on the BD Ratatouille, it gives no sound to my surround speakers. I know they are wired correctly.
Can any of you help and/or optimize my settings? I have a 7.1 speaker system set up.
Thanks!
Bitstream: Select “Bitstream” if you connect the
DVD Player’s DIGITAL OUT jack to an Amplifier or
other equipment with a Dolby Digital, DTS or
MPEG decoder.
PCM (for Dolby Digital / MPEG): Select when
connected to a two-channel digital stereo amplifier.
DVDs encoded in Dolby Digital, DTS or MPEG will
be automatically downmixed to two-channel PCM
audio.
In some case you may need to check the freq as well.
Sample Freq. (Frequency)
If your Receiver or Amplifier is NOT capable of
handling 96 kHz signals, select 48 kHz. so your
system can decode them.
If your Receiver or Amplifier is capable of handling 96
kHz signals, select 96 kHz. When this choice is made,
this unit passes each type of signal through without
any further processing.
Check the documentation for your Amplifier to verify
its capabilities.
http://www.satelliteguys.us/v-recei...-getting-receiver-acknowledge-dts-signal.html
