azbox defaulting on every reboot?
gardo403
224
6
S.E. Wisconsin
I did a install of the latest fw 5306,,, formated the application area for the clean install effect...
I can set video res.. 1080 ntsc etc..... network settings ftp, telnet etc.. to enable
then when i reboot, it all goes back to the defaults:rant:
no idea why it would do that! makes using it real tuff cause it has to be put back into ntsc from pal mode:mad:
im all ears on this one any suggestions please!
This is on an ultra....
So, I stayed up late and re-formated the app area again and re did the install of 5306. Now it remembers its settings after reboots!!! Go figure...
I also N. americanized it too.. so all is well for now.....
I have heard of this happening once before, and I am led to believe it was just a faulty upgrade (some file may not have unpacked correctly the first time). Doing what you did would have been recommended.
Glad you got it sorted out for yourself.
I have experienced where the 're-format app area' fails several times ( I forget the exact error message). I think it was the 3rd try which was a charm.
Have AZBox problem - need some help.
Help with Filezilla, downloading files from AZBOX to PC
