I purchased one about 2 yrs ago, I think ?
Well I got my but in gear and installed on a 10' mesh dish.
I originally purchased it to use with a 922 4DTV receever.
Its a big box, takes up alot of room to set on the stand with the tv.
so rite now i just got the actuator connected to move dish.
I hooked it up like this.
to use single cable to the CW800...
From the BSC 621 pdf manual..
Looking at the diagram, you will see the Ku
connection is at the end of the BSC621. Using
the Coax Jumper, connect it to the port marked
"LNB" on the side of the BSC621. Connect the
coax that delivers signal to your receiver to the
remaining port, marked "RCV".
The band switching is accomplished by 22KHz
sent from your receiver. Setting your receiver
22KHz to "0" will give you C-band, and setting
your receiver 22KHz to "22KHz" will give you
Ku-band
what i dont get is the last part,
band switching
on CW800
22KHz is either ON, OFF, or Auto..
Should it be OFF for C-band ?
and ON for Ku ?
Another question,
Diseqc Number,
seeing as its only one cable and not going thru 4 in 1 switch
the Diseqc settings in menu are:
LNB 1, 2, 3 ,4,
Burst A
Burst B
None
Auto
not sure on settings
From the BSC621-2 Manual
The band switching is accomplished by DISeqc
control sent from your receever. Setting your
receever DISeqc to #1 or A Will give you C-band,
and setting your receever DISeqc to #2 or B will
give you Ku band.
what I am understanding is either use LNB 1 and 2
or
Burst A
and
Burst B
Thnx
for any help and input...
Ku-band
band switching
on CW800
and ON for Ku ?
Another question,
Diseqc Number,
LNB 1, 2, 3 ,4,
Burst A
Burst B
None
Auto
give you Ku band.
or
Burst A
and
Burst B
Thnx
