It's in MY ACCOUNTS in the menuDoes anyone know where the caller ID history is? I don't see it anywhere. Maybe it's just not in this version? Also odd is when you go to the apps screen it's in the old UI format.
I think they are doing away with the quick access to the SW as the new remotes don't display System Wizard on the zero key.
Where are they going to put it?
If you're looking for the remote back up and restore press Menu twice, arrow down to Tools, select Back-Up Settings and you'll find it there.
Picking a result from the search now shows all episodes [emoji106]When viewing a program and you press the "Search" key, it would pre-fill that program name in the search field. Hitting enter would show all instances of that show, including upcoming viewings, episodes on your DVR, etc.
Now it makes it # 0 in the "popular search" list and selecting it just gives you the "Info" screen for that episode. It no longer finds other episodes.
I did, by accident, hit a key (Cancel ?) that actually gives the old behavior but can't remember it now.
Still no luck with home media....Home Media - runs, lists files, etc, but nothing plays.
Anyone confirm ?
It's prepared as soon as recording completes by default now.I also can't seem to find the Prepare For Mobile option for recordings.
Home media works with Playon media server streams but not with recordings
Sent from my iPad Pro using Tapatalk
I have a weird problem or this is another bug. When i pick up something to watch from ehd, all screen becames black except a small square on the right upper of the screen starts showing the show. This happened three times so far. Hope i was able to explain it clearly. To fix it you have to exit from the show, ehd then start over again.
