dvb world dvb-s2
DVBWorld,
Tried to record but nothing was recorded. Counter stayed at 0 mb. Record Icon was lit. File was created but the file was empty. File was .mpg not .ts. Tried a scheduled record. Same thing. I have nothing to send to you.
Joe
pls use the tool :TsCapture.rar
thanks!!
I'm getting frustrated. No capture.
Got the TsCapture file and unpacked it into a folder in the DVBWorld folder.
Started DVBWorld and locked onto a signal.
Closed DVBWorld and opened the TsCapture program.
Pressed "Lock"
Entered in the parameters for the lnb, 5150 in this case.
Entered the frequency and s/r of the signal that I locked with DVBWorld.
Changed file size to 300mb
Entered a path.
Pressed capture.
Nothing captured. File size stayed at 0.
I must be doing something wrong. Should the TsCapture program be in the root directory of DVBWorld?
BTW, on several occasions during my playing around with the programs, the DVBWorld program crashed or the pc rebooted. I recall on two occasions that the pc rebooted when I double-clicked on the TsCapture icon.
Update - Moved TsCapture to DVBWorld root directory. Captured video. Will try to upload to your ftp. File name is "IA5 3840.rar". Played file using Media Player Classic. There is audio on the file but delayed a bunch. There is no audio when viewing live.
Joe
MpegTS with CUEI descriptor
i have downlaoded it and analyzed the tsdata!!thanks a lot!!:D but i also need H.264 TSData!!
the ts data information:
PAT Version Number: 1
Transport Stream ID: 1 (0x0001)
NIT: 131.0W 1.070 GHz Vertical 30000 3/4 8PSK (DVB-DSNG/Turbo/DVB-S2)
PMT PID 16 (0x0010) - Network
PMT PID 848 (0x0350) - Program 41 Bravo
On Table_ID: 0x42 (current mux)
Service Name: Bravo
Provider Name: NBC Universal
Transport Stream ID: 1 (0x0001) 131.0W 1.070 V 30000 3/4 8PSK (DVB-DSNG/Turbo/DVB-S2)
Program Number: 41
PCR on PID 849 (0x0351)
PMT Version: 1
Service name: Bravo
Stream Type: 0x02 MPEG-2 Video
Elementary Stream PID 849 (0x0351)
Stream Type: 0x81 AC-3 Audio
Elementary Stream PID 850 (0x0352)
Elementary Stream PID 851 (0x0353)
Stream Type: 0x86 User Private
Elementary Stream PID 852 (0x0354)
Descriptor: Maximum Bitrate Descriptor
Maximum bitrate: 2244300 bytes per second
Descriptor: Multiplex Buffer Utilization Descriptor
Bound Valid Flag: 1
LTW Offset Lower: 180 Upper: 180
Descriptor: Registration Descriptor
Format identifier: 0x43554549 (CUEI)
Descriptor: CA Descriptor
CA System ID: 4112 (0x1010) Tandberg Television
CA PID 924 (0x039c)
PMT PID 880 (0x0370) - Program 42 USA
Channel 42
Service Name: USA
PCR on PID 881 (0x0371)
PMT Version: 1
Service name: USA
Elementary Stream PID 881 (0x0371)
Elementary Stream PID 882 (0x0372)
Elementary Stream PID 883 (0x0373)
Elementary Stream PID 884 (0x0374)
Bound Valid Flag: 1
CA PID 860 (0x035c)
PMT PID 912 (0x0390) - Program 43 SCI FI
Service Name: SCI FI
PCR on PID 913 (0x0391)
PMT Version: 1
Service name: SCI FI
Elementary Stream PID 913 (0x0391)
Elementary Stream PID 914 (0x0392)
Elementary Stream PID 915 (0x0393)
Elementary Stream PID 916 (0x0394)
Bound Valid Flag: 1
CA PID 892 (0x037c)
PMT Channel 65534
Service Name: dl service
Provider Name: TTV
Transport Stream ID: 1 (0x0001) 131.0W 1.070 V 30000 3/4 8PSK (DVB-DSNG/Turbo/DVB-S2)PID 100 (0x0064) - Program 65534 dl service
hi ,
want this video file for reference of CUEI messages included, so can u please send it to me.
You can watch HD-TV on : HD Pack1.8
Added:
  • DivX H264 Video Decoder v8.1.0.80 (Beta 3 rev80)
  • FFDShow Video & Audio v1.0.5.2206 (rev2206)
  • CyberLink VC1 Video Decoder 2.2.0.5916
Updated:
  • CyberLink H264 Video Decoder 2.2.0.916
  • ArcSoft Mpeg2/H264 Video Decoder v2.25.125.55
Removed:
  • InterVideo Mpeg/AC3 Decoder v9.0.14.84
  • Mainconcept H264 Video Decoder v3.0.7299
Linux Driver DVBWorld 2002, 2004, 2102, 2104
Updated 26.10.2008:
Drivers now included in kernel branch 2.6.28
If you did not find suitable drivers there, feel free to use link: s2-liplianin: Summary
Updated 15.09.2008:
Drivers now included in Steven Toth repository with new S2 API proposal on Linuxtv.
http://linuxtv.org/hg/~stoth/s2/archive/tip.tar.bz2.
Hope soon they will be included in Linux kernel.
Remember, if you did not find suitable drivers there, feel free to use old links.
Updated 20.08.2008:
Velcom to Sourceforge!
http://liplianindvb.sourceforge.net/.
If you did not find suitable drivers there, feel free to use old links.
Updated 07.07.2008:
Version for 2.6.26 kernel and/or latest v4l-dvb. dvblipl07072008.tar.bz2.
Updated 01.07.2008:
Bugs clean. "i" instead of "j" causes driver to hang computer when loading. Thanks to Chris from Cape Town, South Africa. dvblipl01072008.tar.bz2.
Updated 15.06.2008:
TeVii S600 & S400 experimental drivers (not tested yet) dvblipl-tevii.tar.bz2.
Updated 15.06.2008:
Hint for infrared remote. Fixes input device by symlink it. Replace "0x109f" with your card VendorID.
root@vdrbox:/etc/udev/rules.d# cat 55-local.rules# My remote. Add Igor M. LiplianinKERNEL=="event*", ATTRS{vendor}=="0x109f", SYMLINK="input/irremote"Start lircd:
/usr/local/sbin/./lircd -H dev/input -d /dev/input/irremote
Updated 01.05.2008:
Replace archive with new one. Last one was actually gzip format. Now it is truly bzip2 dvblipl06042008.tar.bz2.
Updated 06.04.2008:
Added TV878DS experimental support. Take file: dvblipl06042008.tar.bz2. If You own this card, feel free email to liplianin-at-me-dot-by testing results.
Updated 03.04.2008:
LIRC configuration instruction. In lirc source directory:
./configure --with-driver=devinput make make installInvestigate satellite card input device number:
cat /proc/bus/input/devices Find output lines like this:
..........I: Bus=0001 Vendor=0001 Product=2002 Version=0002N: Name="DVB on-card IR receiver"P: Phys=pci-0000:01:01.0/ir0S: Sysfs=/class/input/input4U: Uniq=H: Handlers=kbd event4B: EV=3B: KEY=3180 0 55007 d30b4fff..........Start lircd:
/usr/local/sbin/./lircd -H dev/input -d /dev/input/event4You'll need to make sure the evdev module is loaded.
Updated 23.03.2008:
Driver for 2002/2102 cards, which do not needs to patch kernel or v4l-dvb. Take file: dvblipl.tar.bz2. Tested with linux-2.6.24.3. Simplified install:
tar -xvf dvblipl.tar.bz2 cd dvblipl make make install This installs modules dm1105.ko and dvb-usb-dw2102.ko.
Updated 22.03.2008: Patch for linux-2.6.23.12. dvb-igorlipl.diff. Tested also on linux-2.6.24.3. LIRC config file for remote control support:lirc.conf. Do not forget firmware for USB card http://liplianin.at.tut.by/dvb-usb-dw2102.fw.
Any donations:
Z340745843664
(c)Copyright. Igor M. Liplianin. 2007, 2008
few request to dvbworld
Few request:
1. Any chance users can set the size for split file?
2. Would be nice to have the dvbworld application running renderless mode when recording, in other words, have video/audio ON/OFF option. This help a lot when recording HD program.
3. Improve http streaming, will be a great feature for streaming program to VLC, other other Network Media Player such as Popcorn Hours, Roku....
thanks,
Added:
Updated:
Removed:
Few request:
thanks,
your question is very good. we will ask DVBWorld company to develop the functions. thanks a lot!!
Hot DVBWorld PCI-Express DVBS2 card
DVBWorld DVB-S2 PCI-E CA&CI TV card is one of the best solutions for you to enjoy Satellite paytv with subsribe smartcard shows on your PCs.DW2005 supports HDTV, Digital Radio, Internet via Satellite, and many other powerful features. The high-tech silicon tuner has a longer life expectancy and it brings your digital TV quality to the next level of visual entertainment.
DVBWorld
DVBWorld
1.Add DVB-S2 PCI-Express DW2005 support.
2.DW2002,DW2004,DW2102X,DW2104X,change WDM drivers to BDA drivers.
3.Add IP support for BDA devices.
4.Load WDM device(USB first),then BDA device(USB first).
5.Fixed the BDA device driver and BDA plugins(for WDM device) to support NBC-QPSK and NBC-8PSK modulator types,with auto FEC search.
6.IR support for BDA device, includes TheatreMgr.exe.
7.Add MD plugins support for BDA devices.Update
MDPilot.exe.
Captive Works
spa
