OTHER FTA Beginner: Trying to use a TracVision R5SL with FTA (pictures)
americajr
San Diego, CA
We just bought a 2008 RV/motorhome and it came with a KVH TracVision R5SL Satellite. While I was looking around at Dish and DirecTv rates I came across FTA. Im very tech savvy but I dont know much about satellites so i'm struggling a little. I bought an X-Squared HD DVB-S2 / M1HD FTA Receiver on Amazon and I can't figure it out.
My question: Is it possible and/or what do I need to do to make these two work together? I'm ok with buying a different receiver or altering the dish.
I have also attached many photos to help out.
Thanks to everyone in advance for any help. Much appreciated!
:helpsign
SATELLITE:
KVH TracVision R5SL
RECEIVER:
Note: I tried adding some links to the manufacture pages of the satellite and receiver but it was flagged as spam. Install guide, user manual, files page, etc
Welcome to SatelliteGuys!
Your receiver should be ok, I don't own one but several here do and like them.
As far as the dish...the one you have is way to small for FTA. It would work fine for DISH or Directv, as they pump out WAAAY more power than most FTA signals.
I recommend getting at least a 90cm dish and you will have to get a linear LNBF to go with it.
You will need to also get a tri-pod or something similar that is portable to set it up on, outside the camper when you get to where you are going.
KE4EST is giving you good information and I second it. Might want to GOOGLE rving with a satellite and possibly FTA and rving. You should come up with some photos of how different people have solved the portable mount issue for rving. If you get the 90cm from Geosat Pro, which you can usually find on ebay for $99 to the door, it comes with a LNB and J pole that is easy to adjust to get it vertical.
EDIT: Better search term for Google: diy portable satellite dish
Here is a link to a mod I did, that includes a simple portable mount. http://www.satelliteguys.us/xen/threads/dish-500-conversion-with-text-pictures.351975/
If you decide to pursue the FTA and rving thing, here is a link to a spreadsheet for calculating pointing/aiming data for satellites. Might seem a bit technical right now, but won't for long. http://www.satelliteguys.us/xen/threads/satellite-pointing-spreadsheet.357002/
Oh, and welcome to the forum. We are all more than willing to help out, so come back with any other questions you might have.
OTHER X2 M1 HD - Polarity Voltage Problem on Ku
AMIKO Amiko Impulse
