FTA? missing channels on the same sat
$835.00
akimbobo
19
is there a reason that I can get some channels in and I can get in
an example would be on Galaxy 23 121.0 west I have no problem getting in the following 2 channels
TVW washington state
the sportsman channel
I would like to get in IMAGINASIAN TV and yet I can't get it in
Any idea or info would greatly help thanks
i have no issues with this channel .... i didn't have it tuned so i manually entered it and it came right up . can you manually enter it ??
it has the same polarity as the other channels listed so that isn't an issue.
deleting it and trying a blind scan now ....
EDIT .... ok i did a blind scan with my coolsat 5000 and it missed the channel but i can manually enter it and get it at 95% signal and 94% quality ( so its not a weak channel )
would it have something to do with pid? I can't turn pids on with the bob jones receiver and I have to wonder if there are certain things I am limited on with this receiver.
I can only enter the SR and and dl freq number I can't enter a vpid or apid number could that be the problem
thanks for the response
put in the frequency, polarity & symbol rate and do a manual scan. It will automatically log the right pids
hmmm I do that and I get nothing for imaginasian TV and some of the other channels are hit and miss also.
I am still trying to get my big dish arced correctly. I can get most of my west sats in and a few are fuzzy. I am sure it has something to do with my problems.
On the other hand if I can get TVW and the other channles in on the same sat I would think that I would also get all the channels in. The channels I do get in are great looking and have a steady signal.
I love the challenge and I am sure it's something simple :)
Thanks for the help and the input
I think some receivers have problems with signal rates below 2000? That being said, I still think it should get it with a Manual scan? However, I know nothing about the Bob Jones receivers, so that may not be a problem?
Al
Also, you might try a Manual scan several times. After all, if at first you don't succeed..............
i think i would try a channel editor and see if its compatable if you have a loader then maybe you can get a channel list and fix it up the way you like and put it back into the box.
just a thought .
My receiver found the TP as 3774mhz @3.007mbs, when I changed it to 3777 @1.860mbs, it locked right on..
Now, if I can only get the DSR-4402x to do the same thing...
I think a 4402x will only do Symbol Rates above 4000 or something like that. I had that problem with a channel on a headend I was working on and switched it out to a SA 9850 it it came in. Then I got to reading the manual and found out it wouldnt do symbol rates as low as I was trying.
I work in Cable TV so I get a whole lot of expierence with the professional receivers.
Wholeshoe
I also work in a Cable Headend.. And you are correct, the 4402 would not lock on to that carrier for anything, so I swapped in a 9828 (which is way overkill, but I could not get the 9223s i had around to kick over)
410 loses channel 215 TV Land
Return the sats to setup list on 4dtv
