off the top of my head:
The diode is easy to replace, and Radio Shack probably does sell some that'll do.
(Ya might want to get a $5 soldering iron at Harbor Freight, instead of $8 at RS)
However, let's take a moment before using any 1N4000-series parts.
They are only rated at one amp.
If this is for the 36 volt side, I believe you should look for 3 amp or bigger diodes.
And it would be wise to ask why the diode blew, too.
If shorting your motor wires took it out, this would be the first I've heard of a chink in the otherwise excellent reputation of the Gbox.
serious edit after closer look:
A quick look at your picture suggests the bottom TWO rectifiers are blow'd up ! -
And just from the way the parts are laid out, I'd say the four smaller rectifiers under the white/yellow wires, are the 1N4000-something, and supply 12v power.
The bigger rectifiers to the left of where the white/yellow wires go through the board, are a full wave bridge (likely) for the 36 v motor power.
Two are certainly gone! - Good job exploding them! - :rant:
So, if both of the two diodes blew, then something major shorted that half of the power supply, and the rectifiers acted as the fuses! -
I'd see if I could locate the cause of the failure.
Shorted wiring between Gbox and motor?
Bad or shorted wire clips at the back of the Gbox?
