Anyone else's guide not updated past Sunday 5:30pm?
Thats about normal, isn't it ?As of 12:46 pm on 2-19-19, my guide is populated to about 7pm on 3-4-19.
You could also save yourself that trouble and do a clearmyboxThis sometimes happens. Try downloading software and it should rebuild guide data.
Reset Genie, as soon as you see a blue light press 0,2,4,6,8,0,2,4,6,8. Software should download. If it continues to load up hit red reset button and try again.
I've found also this happens when dish needs to be repeaked.
Also the instructions you posted don't work on updating the software on a HS17Everytime I get a service call with this exact symptoms it seems to fix itself before I get there. And almost always I have to repeak the dish or change the lnb to pass the IV test due to a transponder failure. You might have to get a service call scheduled.
Only do the sequence 0 2 4 6 8 once. If there is new software in the system it will download. That's usually only from 11PM to 3AM on Saturday night/Sunday morning ET. Any other time you will get the national release.This sometimes happens. Try downloading software and it should rebuild guide data.
Another note about the 02468 - that is for edge cutting software. If you do not have the "IAMANEDGECUTTER" command on your receiver enabled, it can cause things to not work properly. Only download software if you are a part of the CE program.
When I deem it important enough, I'm not afraid to make the contribution.9 1/2 years to make your first post?
to Satelliteguys RaiderPower!
You picked a hell of a time to chime in ....When I deem it important enough, I'm not afraid to make the contribution.![]()
My second paragraph, as worded, is correct.Your second paragraph is incorrect ...
The Iamanadgecutter search has Everything to do with the CE program as it takes you to different servers from what is normally used.
it is not 100% correct as it does more than enable reporting tools.. As Jimbo stated it points the box to different servers for Guide Data and such.. Otherwise as most in the CE program have experienced, if it is not enabled when running a CE most content wont load i.e On Demand, Full Search, Network Apps and HD Assets/Channel LogosMy second paragraph, as worded, is correct.
