Has the HR44 solved the problems with Genie freezing up?
Delay between Genie and client?
OK, another quick question. I have two TV's in the main entertainment area of my basement that I planned to mirror. There is never any reason that they would be on different channels, since they are both in the same room. One is in a built-in entertainment area, and the other is mounted on an adjacent wall where a billiard table will go. Both are high def, and the plan was to just use an HDMI splitter and feed an HDMI cable over to the wall mounted TV. However, it looks like it is going to be a challenge to fish an HDMI cable through the wall behind the built-in entertainment center (and fireplace). An alternative would be to just add another client at $6 / month and use the existing co-ax. The only concern that I have with this approach is that I read on a forum somewhere that you can get a delay of several seconds between the Genie and the client TV when tuned to the same live program. If that is the case, then it could get quite annoying if both sets are in the same room.
Has anyone experienced this, and if so, is there any workaround? Thanks in advance!
that is possible. I have seen it happen before. The delay is minimal in most cases, you may be able to use the volume on one tv for both tv's.
Yeah, I thought about turning the volume down on the wall TV and just using the surround sound. But if the delay is too significant the mouths are out of sync with the words and the broadcast will resemble one of those old Japanese B monster movies.
I guess I could just hook up one of the mini clients and try it out. If the delay is too bad, time to get creative on cable fishing! (My favorite!)
that would be a problem, I thought you were talking about football games. :D
Well, admittedly it will probably be mostly sports when I have both sets on, but imagine how confusing it would be to have Vitale's mouth out of sync! Kind of scary! ;)
seeking Amplifier advise
A new bug with the HR34
