I had Dish Network install about a year ago. When installer left, everything seemed to be working properly. Now, it has a vast amount of problems. Our TV2 wasn't working properly and it wouldn't record on the DVR, "almost like it wasn't getting a signal". It would show the record icon with a 2 on it, but it would never physically show under 'my recordings' and it wouldn't tape.
I tried doing check switch test at that point in time and it said error 836, it found fewer satellites the when first checked. I tried hard resetting the box and it was no help.
It's pointed at 61.5 and 72 if i remember correctly. Although how the installer has it set, is different from the LOS that dishpointer.com tells me.
I marked the spots where the installer had it set for AZ, EL and SK. I then marked them according to what dishpointer.com told me, I was getting 0 signal at those measurements.
I then moved it back to how it was first installed and only a few of the transponders for 61.5 and 72.7 are showing a signal, most of them show 0 and "No Lock"
I also tried to hit 110 and 119 with it, using transponder 11, but I was never able to get a lock with it. It might be because of the place I rent, has trees around it? My zip is 54115.
Picture of my location. I believe this already shows my satellite dish installed on the corner. I circled it in red. Right now for 61.5 its aimed SE, but not to the coordinates that dishpointer.com gives. 110 and 119 would be aimed to the SW. Are those trees an issue? Dish not mounted up high enough on house?
I have no idea what type of dish satellite I have, or what type of LNB's I have. Its a ovalish Dish that is gunmetal with red DishHD on it. The LNB has 2 eyes on it and when I removed it, it showed 1,2,3 as labeled inputs to where the coax was connected to it. I'm Pretty sure it was labeled DP Plus. The Coax on the #3 was just tucked inside the tube and didn't connect to anything.
I have a VIP 722K on TV1 and tv2 is the VHF/UHF input that goes to the upstairs TV.
At this moment TV2 is working great all local channels and SD/HD channles seem to all be working, but TV1 doesn't get any channels at all from what I tested.
Im a quick learner and I know most of the basics about this, I just don't know the best steps for troubleshooting these issues. I dont know if I have a switch or not. I have 2 lines that run from my dish inside my basement, to a simple splitter. From their I only have 1 coax line that runs across to the dish network splitter labeled "SAT IN" "UHF/VHF" and "IN/OUT"
I will see if I can attach a few pictures to help explain it better.
The 2 coax lines from the dish run to this splitter point
From their only 1 coax line runs to this next splitter point. Might be a switch?
I know this a a great site for information and I was hoping someone here could help. I don't want to pay a tech $95 for something I can probably do myself with some assistance.
What are some things I can test, do, look into on my own?
I'll get any information that you might need, or take pics of the check switch screen, the point dish screen, whatever it might be.
Thanks!!!
Thanks!!!
