Pixl - your dish farm sounds like a lot of fun. I'm at 15 myself and wouldn't want to give up a single one. Sorry for the confusion about the 1.8m dishes. I have two - a 1.8m solid petal Fortec prime-focus and a 1.8m Prodelin offset.
The 1.8m Fortec is a flimsy dish, but it performs pretty well on C-band when tweaked. In fact with a single ortho and Norsat 8115s it could lock almost every C-band FEC 9/10 high rate DVB-S2 up there. It ended up with my dual ortho after I decided I preferred the better performance of single orthos for my bigger prime-focus dishes. I had hoped this would provide better Ku performance than my 1.2m GeoSatPro offsets (3), but this has yet to happen. Some of the Ku performance loss may be caused by the Fortec itself, but a lot is from the dual ortho.
Over time I started doing a lot more low-horizon and out-of-footprint work, particularly on Ku. The 1.2m dishes just weren't sensitive enough, and they are highly vulnerable to the high winds we can get. Only one of the 1.2m dishes has a USALS motor, which can't keep the dish from flopping back and forth in the gusts. I put a C-band HH motor on a second 1.2m, but that didn't entirely cure the problem because the 1.2m's mount isn't stiff enough. The third 1.2m works fine in any wind, but it is fixed and anchored both at the back and at the LNB. I love and hate these dishes.
My extreme Ku solution was to find a used 1.8m Prodelin offset. It slams the 1.2m dishes on sensitivity and doesn't budge at all in the wind. It stopped my dual ortho Ku research on the 1.8m Fortec for at least a year, because I don't really need it any more. For curiosity reasons I would like to improve the dual ortho performance on Ku, but that isn't my highest priority.
In terms of your Ku motor project, you have some interesting decisions to make. The 1.2m Prodelins should have impressive performance, but I expect they are way too heavy for an ordinary USALS motor. A friend of mine is planning to build a polar mount for his 1.2m Prodelin so he can use an actuator. He says Prodelin doesn't even make polar mounts for that size dish. If you have or can locate even a lightweight C-band style HH motor, that would probably work fine, too.
My 1.8m Prodelin came with a dual-axis mount, which I converted to a polar mount using a heavy duty HH motor. Prodelin makes a polar mount for this size of reflector, but they want a lot for it. It's an incredible dish and highly recommended for power users. I see unused ones everywhere I go, but almost all of them have only AZ/EL mounts. They're often available for free, but they would require some work to motorize.
In your case I think your best option is to look into motorizing your 1.2m Prodelins. The 1.8m Prodelin is a nicer dish, but motorizing it isn't any easier unless you want to pay Prodelin for the luxury. I would stay away from a prime-focus dish for Ku-only unless it's truly designed for that purpose. Few are.
