HR-20 Internal Temp
joedekock
1,136
West Michigan
My HR20's internal temp is reading 120 degrees Fahrenheit.
Could others post what theirs is? Where I have mine set up does not allow any room for ventilation on the top of the receiver, and I want to verify with others to make sure mine is not running too hot.
I have not had any issues with it at this temperature and it has been this way for a week now.
Jimbo
70,411
8,839
NW Ohio - Buckeye Country
Joe,
You have nothing to worry about.
Normal temps run between 120 and 127* any higher than 127 I would look into.
Mine is currently running at 125* but it will vary from time to time.
Jimbo
Jimbo
70,411
8,839
Hey Jimbo. Mine at home is usually around 123(open air) but my in laws here have it enclosed and its 130. How bad is that?
I wold start to keep an eye on it, It may be no problem at all, but ya never know. Is it doing anything flaky at that temp ?
Also check it (temp) more than once, it will vary from time to time.
Jimbo
Bob Nielsen
1,721
Bainbridge Island, WA
My HR20-700 typically runs 122-125. When I first got it the temperature was 127. I haven't had any problems which would be considered heat related . The -100s run cooler. The H20-600 is the really hot receiver (sponaneous reboots, even).
mdriskell
Sep 28, 2007
While on the phone with tech support tonight the guy told me something I think might prove handy to some. We all know that the USB ports are not active yet, but they are powered. If you have your HR20 in an enclosed cabinet you could get an USB fan to help provide additional airflow. I wish I had thought of that when I had my old MOXI cable box that thing was an oven.
Jimbo
70,411
8,839
Many of us have added external fans already, I have mine plugged into the wall with an On / Off Switch.
Jimbo
HDhysteria
252
40 miles west of chicago
even more damaging than heat alone is the mechanical stress induced when the boxes are turned on and off. This causes expansion and contraction of all the components which over time causes mechanical failure of the internal joints.
ShadowEKU
Expert in the Making
1,829
Frankfort, KY
the only way to turn off these receivers it to unplug them....
hell you can still hear the HDD going in the HR20s when they are "powered off"
DTV_Guy
Oct 18, 2005
19
My HR20-100 averages at 107 but will go up to 113 if my Xbox 360 has been in use since it is in the same entertainment center next to each other.
gadgtfreek
22,105
865
Lower Alabama
I just got back home finally(gone for a month) si I could check out the temp on MY HR20. Its 127 sitting in an open air ent center, no way to get it any better without a fan.
Multi- Room
Which generations of tuners works with 3 LNB's?
