I'm very confuse
vargf
47
I have 2 FTA receivers one is the fortec Ultra life and the other is the Pansat
500CI double PCMC or whatever, but the question is
why on my Fortec ULtra Life blin scan I can get all channels on Solidaridad 2 at 113.0°W ; while in my Pansat 500CI just I receive 1 channel from Solidaridad 2 at 113.0°W ? is bad Pansat reciver? I confuce?
Any idea.
:confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused:
I put the Freq as I received in the Fortec receiver , but no quality signal I mean 0% signal may my Pansat 500CI is bad.
If the Fortec is the Master and the Pansat is the slave, the Pansat will have to be on the same polarity as whatever channel you have the Fortec on. Assuming you are slaving it, it sounds like maybe the frequency you entered may be on the opposite polarity. If that is the case, you need to change to a channel on the Fortec with the correct polarity. If this is not what's happening, how are the Fortec and the Pansat hooked up?
Al
Pansat 2500
Fta Receivers
