iOS7 Discussion Thread
Sweet. Not a total wipe. THANK YOU. Doing it now…
(I knew about Option-Check for Update, just was afraid it would do a wipe, like some of them do… )
Damn, I wish I'd have read this stuff first... Restoring now. At least you saved me time on my iPhone...
I would have done the exact same thing.
Looking forward to a report on the iPad; particularly if it stops those constant springboard crashes, where the menu bar of apps moves up the screen.
I loaded it on my iPad but haven't played with it yet.
Why did they change the tri tone sound?
The iPad has been running good, although I am not sure yet on battery life. After the GM was installed my battery level was 56% my son used it and watched YouTube for about an hour, then I used it reading different sites for about an hour and now my battery is at 42%
I haven't had anything crash no any other oddities.
I downloaded the 4S ipsw file (I have someone on my dev account with a 4S), got him the file, and the file inside the DMG is labelled iPhone 4,_7.0_… AND when he went to update it, it said "wrong firmware"
WTH? The DMG file is for iPhone 4S. Re-downloading it and hopeful it was a glitch, but I am kind of baffled.
I'm using someone else's account and get an error code 3194 when I try to install. I tried all of the tips on Apple's site, but still the same error. I have a 4S.
Mine is down fast today as well! Havent used it and was down to 36%.
Looked to see if I had any programms running and nothing was running. :(
Ok, thank you. You are confirming a problem. Did the error say anything about incompatible firmware?
It didn't.
It gets to the point where it's verifying with apple and then I get the 3194 error. I've rebooted, turned off the firewall, downloaded it twice.
I re-downloaded it, shared it with my friend, and he reports it is working. Strange.
My issue is that when I installed the previous download it was from a direct link. I used the same link and got the same file. When I get home I'll go to the download section and I should be able to download and install the correct version.
38 million iphones to China Mobile?
