Ku band LNB on a 18" DTV dish..can it work?
$905.00
Bill_KY
713
Northern Kentucky
Hi
I have a extra Ku band LNB, I have a extra DTV 18" dish and a extra DTV Direct way Dish (Pre Hughes net), also I have a adapter that would fit the LNB on a DTV 18" dish. I also have a extra FTA Ku Band receiver.
So can I use the 18" dish or the old "Direct Way" (Pre Hughes Net) dish with a Ku Band LNB with my Ku Band receiver ...or do I need to pick up another 76 cm Ku Band dish.... I would use it for Galaxy 19.
Lastly, does anyone know of any FTA satellite dealers near the Cincinnati/ Northern KY area? Closest I see is Columbus Ohio. If I did have to buy another 76 cm dish ... I'd like to pick it up myself.....
I assume you have the white and very wide elliptical DirecWay dish.
The existing LNB on it is fine. LO = 10750
The feedhorn matches the dish quite well..
That would be a better solution than outfitting the dish with a 3rd party LNB (though that should work, too)
If you wanted a very strong FTA signal (there are a few), then a small dish with a linear LNB is passable.
Here's Whitesprings on a DirecTV Phase III dish, just for reference.
(not necessarily a recommendation) - :rolleyes:
You could try it, but an 18 inch dish will only work well on the strongest linear Ku transponders. You'll likely lose signal if there are any storm clouds around, and you won't get a hint of a signal on the weaker transponders.
Yes... The 18" DTV Dish works for me
You can receive a lot of the satellites in the North American arc with the 18x20 DTV dish. I use to use it all of the time for Galaxy 18. I only experienced rain fade a couple of times; it was mostly when there are black rain clouds in the area. Don't expect to get strong quality reading and all of the transponders, but you can enough to make for interesting viewing.
I also used it for satellites that do not have a good LOS from the front of my house. I travel to a location that would have good LOS and use the DTV dish. Look at the pics, included is a pic of an experiment on finding the focal point by tuning the dish with the sun.
I just retired my 18" DTV because I bought a DN 500 off e-bay for 99 cents plus $10 shipping. I'm in the process of rebuilding my test setup.
Good Luck,
Mike Lib
Mike - looking forward to a thread with your Dish-500 antenna, in the future.
You know, some crazy SatGuy put one on a motor a while back. - :rolleyes:
Shouldn't be hard to search for.
As to your DirecTV dish, that appears to be the same 20" wide (18" tall) Phase III dish I used in my Whitesprings experiment (link above).
I was very careful to put the LNB mouth at the exact same location as the original LNB, and yours seems quite a bit more forward toward the dish.
As for the Dish500, I found their shorter LNB arm less convenient.
The dish width is about the same 20", which affects adjacent-bird suppression.
The 22" height just gives a little more gain.
Given optimum LNB location on both, I would be surprised at much difference in reception, and look forward to your future report.
Here is a picture to help locate the new LNB on any such dish.
I wish I'd had it when I did mine. - :rolleyes:
PS: If you stumble over a SuperDish (36" x 20"), or a newer DirecTv dish (22.5 x 32.5") with 30-some inch measurements, give one of those a try. - :up
I will post my new test setup as I found out that a J pole is better then a straight PVC Pole. I will take pictures for your amusement.
Last month I was visiting my daughter in Charlotte, NC and I bring along the 18x20 DTV dish with a tripod and a motor. I motorized the dish and was able to get an arc from 72ºW to 123ºW.
Actually the LNB is in the original LNB spot. I used W1GHZ trick of taping a string from the top of the Dish to the DTV LNB and taping it to the bottom of the dish. If you observe the arm of the dish you will notice that there are 2 screw holes. (check sun experiment pic) There is approximately 3 holes each spot can be used for mounting the LNB bracket the hole closes to the reflector gives the best signal quality.
The 500 Dish performs well, it is much better than the 18x20. My most South sat H2 comes in at a 65 SQ on my Fortec Dynamic receiver.
Thanks I will print it out and keep in my files.
I'm trying to stumble over one of those white dishes you see on gas station or a directway dish. You know it's hard driving and looking for abandon gas station that still have the dish on the roof. :up
Bill -
Even though we were talking about using too-small dishes, I did say pretty clearly at the top of this thread, that your DirecWay dish was the way to go.
I hope you took that advice.
Here's good reading in a similar thread to encourage you along that path.
I agree with Anole. I would use your 18" dish for NASA, ION, or Angel One on 119W if you are interested in those channels. If you aren't I wouldn't even bother with using it for anything else since you have a Direcway dish you can use instead. I use an 18" for NASA and ION, but the only reason I do is b/c it was already on the house and aimed at 119W when I moved in.
Here are some more uses for an 18" dish:
How-To: Build a WiFi biquad dish antenna (I am actually in the process of making one of these. You can buy kits with all the required parts on ebay for $25. they have a few miles of range)
DIY Friday: Satellite Dish Bird Feeder | Really Rocket Science
[ame=http://www.youtube.com/watch?v=G9f5hlBrqvg]YouTube - Food Series - Satellite Dish Solar Cooker[/ame]
ONN comes in "fairly" good with a 18" dish. Usually get around 60% until the rain comes. Then its just about nothing.
Hi, you can call us at 1-888-519-9595 and ask for the phone # of Touba in Cincinnati. He is a dealer and buys dishes from us. Sorry I don't have his phone # with me and I am away from the office.
Followup
Here is a followup on my experimentation with a 18" Direct TV Dish with a Ku Band LNB and adapter bracket. I was able to get a 73 % level and 24 % quality. The TV signals breakup often but the radio side seems to be pretty stable.
I can't experiment with the Directway Dish due to the dish is in parts and the four nuts and the wedge and bolt needed to assemble it are missing.
But anyway...it was a interesting experiment...more later
What sat/channel were you aiming the little dish to? Not too bad for an experiment.
Hi
Call this number and ask him but be carefull of him, he screwed me once about 8 years ago for $350 on a receiver
800 864 4046
Call Tom Taylor 859 356 9666 in KY a real good guy he will never screw you he's the the best and a great friend with a great heart
Or call Mike Kohl 608 546 2523 WI another great friend
DirecWay? Not a problem:
If you want to get it going, shoot us some good pictures of what ya got.
My bracket is currently in my bedroom, and I'll shoot you some pictures of a complete one, if it's necessary.
Otherwise, I'm sure we can come up with a hardware list to get you running!
Don't think any magical parts are needed... but if they are, I also have an industrial supplier who really is looking for business.
What's New At Skyvision?
Upside Down or Inverted Dish Installation.
