Latest Update at my Satellite Station
cyberham
6,399
5,506
British Columbia
It's a slow night, so I thought I would share my newest toy at my satellite station.
This is my 7.5-foot Perfect prime focus dish which I retrieved from rural Nova Scotia in 2012. I've never installed it until now. For the last few days, I've been manually pushing it between 139W through 87W to check out the arc and see that it functions as it should. It's working very well and receives almost all transponders from these satellites with good C/N levels even though it's only 7.5 feet. I think the Titanium C1-PLL LNBF is an important part of it working well. You will notice the post is a little unconventional but I'm satisfied the installation is very stable and will withstand the winter weather at this location. It's view is actually from about 150W through 82W but there are no satellites west of 139W and east of 87W to the start of the forest trees at about 75W.
I installed the unpowered Von Wiese jack that came with the dish only to hold the dish fixed during testing so I could manually change the azimuth. Now, it would be nice to move forward and actually try using the Von Wiese to push the dish. For this, I need to source 100+ feet of power/pulse cable plus a mover like the VBox. I'm not sure where I would source these from.
In the meantime, it is thrilling to experience C-band with more than a 4-foot dish as I've done over the past 5 years. When I see the powerful transponders on satellites at 105W and 97W, for example, I understand why I was able to receive them even on a small 4-foot offset.
View to due south from the dish's point of view:
Congrats on getting your c band dish up! 😃
Rick's Satellite has the PR1200 dish mover. Not many options out there these days so maybe best to grab one while they are still available.
:yes
As far as cable goes I have used multi-conductor underground sprinkler cable for our 100ft plus run. Two wires for the pulse plus two-doubled up sets of wires for positive/negative voltage to actuator. While this type of wire may not be the best choice because of the possibilty of introducing noise in the pulse counts it was readily available from the 'box stores' and has worked fine for our setup for over a decade. YMMV. ;)
Good luck! :)
...Rick's Satellite has the PR1200 dish mover. Not many options out there these days so maybe best to grab one while they are still available.
:yes
That was my thought too. I wouldn't mind supporting him as well.
... I have used multi-conductor underground sprinkler cable for our 100ft plus run....
I'll research this. I would likely need to go into the big city for this. Not likely justifiable to have this bulky item shipped.
Reactions: FTA4PA
We are in the country as well but near enough to the box stores that I was able to pick it up. When I did the run a decade or so ago I simply could not find 'the good stuff' anywhere so I chanced it with the sprinkler cable and it worked out fine, no interference.
Reactions: cyberham
I've heard shielded alarm wire is also a good choice for the pulse wire run if you require separate cable runs.
Has anybody tried using a dedicated run of RG6 coaxial cable to carry the power? It would need to be about 150 feet probably. The centre conductor of RG6 is typically 18 gauge. I think this is too small gauge to carry power that far. The beauty of using RG6 for the power and the sensor wiring is I can use my standard window feed-through flat cable to get it through my house window.
Added: I see there is 16 gauge RG6 cable available: double shielded variety.
Good idea for the motor wires: HomeDepot
Reactions: one_db_compression
i'd be worried that the windows pass-through would be lighter gauge since it needs to be thin and flexible. I woudl suggest monitoring its temperature
Reactions: primestar31
For the power conductor to my actuator, I use Low-voltage outdoor lighting wiring (landscape lighting cable), I believe 14-16 ga-ish? The sensor wire side of things is a menagerie, consisting of landscape lighting wire, then spliced to some CAT 6 I had lying around, then spliced to a short lead of the original ribbon cable on the actuator. Not elegant, but works fine. Keep in mind my distance is ~75' by the time the wires make their way into the house. I mainly stay parked on 101W, but it has done me fine moving 93W to 105W. My dish isn't well aligned for the whole arc, can't see east of 93W anyway.
Reactions: cyberham and FTA4PA
...I mainly stay parked on 101W, but it has done me fine moving 93W to 105W. My dish isn't well aligned for the whole arc, can't see east of 93W anyway.
That's the sweet spot anyway where most of the ITC stuff is. The second I attempt to motorize, I will need to get out the PB Blaster and get the declination bolt freed up. This dish was last mounted in Nova Scotia so this adjustment needs attention but I know in advance because of this that this adjustments must be modified by about 5 degrees in elevation.
The other problem I have is that there is only one connecting tab for the jack arm: on the right side of the mount. The manual says since I'm west of 104 degrees longitude, I should mount the jack arm to the left side of the mount. Since I can't do this, I'm not sure how much of an issue this is.
A few random thoughts...
I regularly run over 50 Watts over 150 feet for outdoor microwave radios from proprietary Power-over-Ethernet injectors using 23AWG twisted pair. You will likely need to use two pairs for + and two pairs for - to get an equivalent cross-section as a dedicated 18AWG conductor.
18AWG at 150 feet with a 5 A load with 36 Vdc across the terminals is going to be pushing toward a 20% voltage drop, so I suspect you'll be in the 28 to 30 Vdc range at the end of the run.
So to be practical, you might be able to get this to work with a single run of twisted pair or coax, but two parallel runs would be better.
In a perfect world, to handle that current and to keep the voltage drop below 5%, you would need to run 10AWG. (This is coming from a guy who is installing 50 feet of three conductor, #1/0, armored Teck 90 cable for an outdoor sub-panel at the edge of his deck.)
Your mileage may vary.
I'd probably get a minimum of 16 gauge lamp/speaker cable for the power. Motorizing may not happen so soon, if ever. I'm enjoying just pushing the dish to the next satellite and staying on it for a few days to see what's there. Now that I've scanned in permanent tps for almost every satellite, it's easy to find them again.
Yes, one of the last revisions developed of the Vbox. Heck of a good price for a NOS unit. Buy it if you haven't already done so!
At that price, I was going to buy it regardless. I've bought and just arranging to get it now.
unimesh 12
Another C Band Rescue Mission
