LNB Splitter
kdjuan
153
23
I installed Orby using my 4ft kuband dish which has a motor on it to tune to other satellites.
My question is how can i split the coaxial cable so that i can use both orby and my FTA receiver.
Currently iam using a A/B splitter but i have to get up and switch it. I was wanting to be able to switch back and for with out the A/B Splittter.
What kind of switch will i need.
truckracer
4,338
352
Charleston wv
If it's a dual output lnbf , connect the orby receiver to one port and the FTA receiver on the other port. Two coax cables ran out to dish.
Sent from our Pleadian star ship
Reactions: FTA4PA
KE4EST
SatelliteGuys Is My Second Home
Staff member
HERE TO HELP YOU!
27,054
7,369
EM75xb
Kevin, like truckracer mentioned, you will need to run a dual output LNBF. Make sure you get one that has a standard 10750 LO. A lot of the dual and quad LNBFs on the market are universal.
kdjuan
153
23
okay. So once i get a dual LNB can i put a switch outside on the dish so that i wont have to run another cable. If so what kind of switch do i need to put on it.
Titanium
AI6US
7,708
9,217
Meadow Vista, Northern California
If you use a splitter, the FTA STB will need to be either placed on a vertical transponder (13Vdc) or powered off when the Orby receiver is used. If the FTA receiver is powered on and tuned to a horizontal transponder, the Orby receiver will not see the vertical transponder.
Also, the Orby EPG data may be outdated for a period of time when the dish was not aimed at 117w for a while and/or the FTA STB was tuned to a horizontal TP.
Magic Static
7,498
4,853
Montana
Actually you want to power off the one receiver before powering on the other. You don't want to confuse the "diode steering" function of the splitter. You have the same capabilities as with the A/B switch and no more. You just don't have to get up and switch it :)
I use three receivers sharing two motorized dishes with a three way splitter. :)
primestar31
14,987
17,942
Beta Omicron Delta III
IMO, run a second coax cable, and while you are doing that, install a second fixed dish JUST for Orby. You'll probably want to do it soon after trying it the way you have it now, so beat the rush and just do it right away.
Reactions: truckracer
Z_finigan
Sep 27, 2016
31
12
Florida
Here is the answers for you.
If you just want to use Orby and have other uses for the satellite. Then a splitter is fine. But it has to be a full range. Up to 2ghz
If you have a system. Like I do or even just a ku satellite and want to use the fta also..
It's going to need a switch. The best one I like is a 4x8 powered switch.
This is the best for fta boxes to. As the box then does not have to power the switch or lnb. Which I had an old 4x4 that was not powered. And would over heat the box
Now mind you Orby satellite receiver is defaulted on 22k.
So if you use it with a 2 satellite system. It has to be on the 22k 13/18
But with this. I can move my Orby anywhere in my house. And it works on all 8 outlets.
I have 2 satellites c band and ku band.
And I have 2 control boxes.
Satellites 1 to 20 c band
20 and up is 2nd box ku.
kdjuan
153
23
Well Orby i was just trying out and seeing if i could get it to come in with my ku band dish and they had orby receivers half priced. So its something i would use every blue moon. So no need for a another cable ran.
truckracer
4,338
352
Charleston wv
I would get the 70.00 orby dish honestly. For the price you cant beat it. Your epg will stay up to date.
kdjuan
153
23
iam not going to do pay ever month i may not get it again for another 3 months or so. its not my main source of tv. just wanted to see if i could get it with my ku band setup.
Reactions: KE4EST
Frustrated with Orby
Factory Reset Orby Receiver
