Need some help - 8 foot Unimesh install
I'm not sure what you are trying to say.
It's all open for interpretation ...
It's all open for interpretation, you say.
The steps of what to do, described in these "secrets", are clearly described I would say, so not open to interpretation differences.
So the only thing left for interpretation, would be if this procedure (these steps #6, #7 and #8) make(s) sense, or not.
I explained already why they don't make sense.
You didn't react to that explanation. Nor did you respond, that anything was unclear.
So to me it looks like we have different "interpretations" of what steps make sense, or not. Of what is an effective procedure, to get "acceptable results", as you called it.
You are absolutely in your right, to have your own beliefs.
You have lost me on this point, though.
Greetz,
A33
Reactions: arlo
It turned out the north/south axis was pointed too far east, as in the picture above. One we got the dish moved 5-8 degrees west, everything tracked.
We now have signal on satellites 87-123. The house gets in the way of anything west of that.
Thanks everyone for the advice (especially the diagram)!
PS- we swapped the actuator for a Venture Mini from Rick's- works very well.
Greetz,
A33
Nah, TRG, you guy you. Nothing started. Interpretation maybe. I'm seeing a propensity. Trait? By a33 to draw to conclusions. Not here but on other places. I ain't good. Not the best. A bit of a smartass here and there. Got baited into heated and vile discussions and booted from forums. Been called or hinted an idiot. By moderators who have the power to. Without notice. "There is a problem". "You've been banned". Not my intention no-how, no way. Backbone. No soap box. If I can't afford it. I save up. Or I make it. Or make it better.
This forum? Dishes? Mine was put up in 1984. Back when analog didn't require the finesse needed today in setup. When Satcom 4 and a few other on the Western arc were all that installers cared bout. And. I've only been into this stuff for oh, around 6 years.
Yaaaa. 2 broken back episodes. Last during Covid. Advil burned my innards out. The doc put me through physical therapy until I couldn't walk anymore. Lyme disease. 17+ years of the indiustry that gives "postal" its true meaning by a private corporation who's only concern was $$$. Can I please be allowed to enjoy life now? Do what I want to? For Pete's sakes.
#6 Now, you have to get the dish to track on the sides of the arc.
DO NOT adjust any elevation angles on the mount at this point! Move the dish using the actuator to a satellite on one side of your arc.
Interpretation: Stay with known and specified elevation and declination angles. To avoid the urge that to blindly vary correct and proper geometry. Those were dialed into your polar mount and in the end should be very close to how it was setup initially. It's set, DO NOT ADJUST. Yet!
You should hopefully see the signal from the satellite, if not, pick a
satellite closer to the center of the arc.
The difficult part for everyone. Finding that first satellite and transponder. Perhaps "easier" with reflectors having perimeter supports that the scalar is fastened to. The LNB could be tilted slightly in the scalar. Focus will not be set to give a strong signal. Little to no experience to realize which is the "hot" transponder for your intended satellite.
CENTER OF THE ARC. Not zenith (dish in the air). A midpoint of either the Eastern or Western arc. USA would probably have you on the Western arc. Midpoint would be between for example 127W and 84W. 105W works. Hot transponders there. 99W might be better for my location at 72 West Longitude. Because 45W would be the closest Eastern compliment.
DISHPOINTER! Hey, what an idea!! True South runs right through the garden to the scarecrow from the dish pole.
Next, you have to push or pull upwards and downwards on the dish.
You don't have to use much force, just a bit to see if the signal gets better or worse when you push/pull on the dish.
What you are actually doing is to change the elevation angle a bit. Yes you are.
If your dish is pointing at a satellite to the east of center and you have to push up on the dish to get a better signal, then the elevation angle must be adjusted higher. For me with a buttonhook feed, the opposite is true. I had to "Watney" it. Perhaps the fiberglass is flexing and the feed is stationatry?
You adjust this by turning the WHOLE mount to the east!
Granulation time. Read it again. And again. You need to adjust elevation higher. Turning the mount East steers you past the satellite. When you return the dish to tagrget. It will track slightly higher in the arc. And if not (at zenith) pointed exactly true South. Will leave Western arc satellites low in tracking. Works on paper. Has on bar napkins for me after a brain-wreck day where it all hit the fan.
You have to use the actuator and move the dish a bit west to peak the signal. You go back and forth until the dish has the correct elevation.
Your dish mount elevation is fixed from setup. DO NOT TOUCH (now).
"I'm just a touch high on this side but too low on the other". "If I swing the mount this way, the satellite get's higher on that side and lower on this". At first things smell a bit like opening that bag marked Martinez to make 'tater fertilizer. It will make sense soon.
Next, you have to check a satellite on the other side of the arc. If you peaked the dish for center, and then for one side, the other side should be very close.
This will depend on your ground pole, offset angle/elevation angle and quality of feed/dish.
Ahhh. That 'tater dipped in Vicodin took the edge off and now you can focus.
#7 If your dish is not hitting center on the other side, try the same adjustment as above.
If the dish needs to be pushed up to get a better signal, then TURN the WHOLE mount in that direction.
If the dish needs to be pulled down for a better signal, then turn the mount the opposite direction (towards the higher point on arc).
Then, armed with the Philosophy of Tuning Dish to Satellite Arc diagram. And actually absorbing the concepts. Things make more sense.
#8 Then, go back and check the other side. Hopefully, you're not far off. You might have to go from side to side before your dish tracks perfectly.
Too high, low both sides. Worse towards the lower portion of the arc. But not so much at the top.
Not so bad on either side but man!. The tops really suck. At least we are pointed in the right direction.
Pretty darned close anyhow.
This one's for you aaaaaa33
Quick update on the 4:2:2 front. We acquired an Ericsson RX8200 from Ebay. It can directly display 4:2:2 on the TV using SDI output, fed into a cheap HDMI converter from Amazon.
Currently it's licensed for MPEG-2 and h.264 MPEG-4 only, but it is capable of HEVC h.265 4:2:2 decoding. It is fun to be able to display 4:2:2 "on the big screen!"
There are endless options on this receiver. Here are screenshots of the dashboard and photos of the receiver displaying the women's golf tournament from Portland. Source is two 16APSK muxes on 89 C-band.
The receiver has 4 inputs, so you can have KU and C-band side-by side.
congrats on scoring a cool receiver. Under Device Info what do you see? Also what is listed under Customization tab.
If you already had a receiver that could decode and output 4:2:2 directly, why didn't you say so before? Others have asked about which model(s) to buy but nobody ever says anything.
LOL, I wish that was my receiver. Its a screen shot from $4000+ model on ebay. This isn't mine either but it appears to have license support for HEVC 4:2:2. Maybe when I win lottery I'll get one ;)
Reactions: N5XZS and FTA4PA
We didn't pay anywhere close to that. The Ebay seller is swapping our RX8200 for one that has the proper licenses for HEVC 4:2:2 decoding. I'll post some sceenshots when it gets here
The swapped-out RX-8200 arrived today. It's playing the HEVC 4:2:2 CBS muxes on 93 and 97 just fine, but not ABC on 99. Is there something funky about ABC on 99?
I understand that DVB-S2X is complicated. Take a read of what el bandido has to say about DVB-S2 vs DVB-S2X.
In particular, note this:
"...And to say a receiver is DVB-S2X capable is in a way a stretch because DVB-S2X means more than one thing. The manufactures to date do not give much detail on how capable their DVB-S2X receivers really are. Instead they simply say DVB-S2X and hope we are too naive to comprehend anything else I guess."
Reactions: FTA4PA
It must not be *too* complicated because the V9 Prime can decode it and play it back on the iPhone app
I stream via my wifi to my laptop running PotPlayer and connect the HDMI port back to the TV. I have no way to view 4.2.2 without streaming.
It occurred to me that I don't even need to use a PC to view 4.2.2. I can stream wirelessly via wifi to my smartphone from the Edision's web interface. Once viewing 4.2.2 on my smartphone (which it is capable of), then I "cast" the video wirelessly back to my big screen. I can watch 4.2.2 without wires and just using my pocket phone as the intermediary. Phones are powerful tools nowadays.
Reactions: comfortably_numb
Control C-band actuator remotely?
BIG Powerball Up Coming Weekend, Satellite Feed
