I would hook it up without the motor first to get an idea of where you need to be.
Your lat/longitude is right and SBS6 is your true south.
elevation of a fixed dish is 43
azimuth is about 195
So put your dish at 43 elevation and straight south
make sure you are using one of the ports on the LNB that says "L" and remove ALL switches
Go into the setup menu and select SBS6. It should be in there. Set up the LNB as follows
LNB Single
LNB Frequency 10750
22k and Diseqc needs to be set to off
Save it (exit out) and go into Manual Scan. There should be a transpnoder that has the following
-frequency 11742
-polarity H
-symbol rate 6616
That is Ohio News network and is very strong.
Now you should have red bars at the bottom that fluxuate. The bottom one is the one to worry about. When you have signal, they turn green. Slowly turn the dish west a little bit and WAIT 5 seconds before moving again. Ku takes a while to acknowledge the signal. When the quality bar turns green, then you are on the signal and you can fine tune.
ICE - Viewing your expertise on these subject matters (from you responses) - you should consider teaching classes on the specifics.:up . I am still lost where some of these terminologies are concerned. Hope to get somewhere close one day.
no thanks....I'm not real good in front of crowds
