In my quest for better equipment I've been considering putting PLL LNBs on my Bullseye II feedhorn. The use of the Bullseye is enabled by using a multiswitch. I'm using the WNC-SWA48 that has been modded to increase voltage to the vertical LNBs. On one setup I have Norsat DRO LNBs, 2x 8115 C-Band and 2x 4106A Ku. The current draw spec on the C-Band LNB is 130ma and the Ku LNB is 120ma for a total draw of 500ma on my switch. The switch has a power supply putting out 1.0amp at 24v DC. The Norsat PLL LNBs consume way more power. C-Band LNB is 330ma and KU is 200ma for a total of 1060ma draw. I'm thinking I might be just over the limit of the switch. The variable is the voltage spec on the LNBs of 15~24 volts. Is the current spec at 15v or 24v? that would change the power consumption in watts quite a bit. Going to PLL LNBs may not be a simple bolt-on operation, ain't it always something?
