I bought 2 preamp's today![]()
Actually, I think only the one in the white box is a preamp. The other is a signal amp. The preamp is designed to be mounted as close to your outside (or attic) antenna as possible
Amplifying a signal that is weak because you're using the wrong antenna isn't going to help much. Three times nothing is still nothing.
I know it's the wrong antenna, but I'll still need an amplifier when the 7 footer arrives [emoji4]. I had some time on my hands today so I decided to try once again on my Clearstream. I added the amp, redid the mast, and pointed the antenna. Amazingly, it worked! CBC isn't pixelating anymore and I'm getting all my local VHF channels plus TVO which I wasn't getting before. The only thing that's concerning me about the RCA TVPRAMP1Z is the short piece of RG59 going from the power inserter to the TV. Other than that this preamp helped a lot! View attachment 133285View attachment 133286View attachment 133287View attachment 133288
Do you have a TV with an OTA signal meter, or perhaps access to an HD Homerun tuner? If so, you can fine-tune your antenna(s) and make minute adjustments while watching the meter. It's difficult to adjust an antenna with more than just "point and pray" when you're aiming blind![]()
I've found this $30 8 foot antenna on Craigslist and I don't know if it's worth it. How directional is it? Im going to mount it in the attic and I don't have much room for pointing it. Is the Steller Labs 8 footer still better?![]()
For the most part you're going to need to be able to point it at the station.How directional is it?
He wants to stick it in the attic where he is just as likely NOT to be able to point it at the station.
The pictured antenna, assuming it is undamaged, would be a great choice. It looks like a Radio Shack VU-60 or maybe a VU-90. Comparable antennas sell for upwards of $65 new.
At 50 miles, you're probably not going to want to bury whatever you use in the attic. YOU CANNOT RECOVER SIGNAL THAT YOU LOSE BY PLACING THE ANTENNA POORLY.
It will likely need more than a single story attic worth of elevation and it probably won't get enough signal through your roofing material unless it is lightweight fiberglass.
This is why you should present us with a specific goal/problem in your first post before you've started ordering stuff willy-nilly.
Those are regular asphalt architectural shingles.I can't put the antenna outside or strap it to my chimney. The best I can do is a attic installation. I don't know what materials my shingles are. It's just plywood and the shingles View attachment 133357View attachment 133358
