- Looks to be 4 to 5 foot ,you can fold the V reflectors down,if that helps.Take a pad and strap it to the roof.
im not sure but that's what it showed in the VU-160 manual.
Sent from my LGMS631 using the SatelliteGuys app!
Are you sure that is a VU-60? It looks like too many elements for a VU-60, maybe a VU-120?
Oh and it's 11feet long,so I'm thinking the 120 is probably about 8 or 9 foot.
Probably not drastically but it may be noticeable. Of course since you have nothing to reference to, you won't know by how much.It's missing 3 elements, two UHF ones and 1 VHF one. I have the VHF element. Are these elements so important? Will it drastically impact performance?
If you snap off one of the long elements at somewhere other than the rivet, you may be able to sleeve it back together by slipping the two pieces that used to be one over a smaller METAL tube or solid METAL rod. The metal isn't entirely important as long as it conducts electricity but aluminum would be best. The overall length of the element or its position relative to the other elements must NOT change significantly. The diameter is inconsequential.
The key to success with any antenna is don't twist it into a pretzel or break pieces off of it. This goes for TV antennas as well as satellite dishes. Each element is "tuned" to either capture or reflect certain wavelengths and part of that includes the spacing between the elements.
The elements you "fabricate" should be the same length as the ones that they replace. Hopefully you have the partner of each of the broken elements as a reference.
Every shortcut you take will subtract from the overall effectiveness of the system and I don't use the term "system" lightly.
