Question about using a DN dish
Bobby C
69
5
Oklahoma
I have recently aquired a new 24" dish network dish it is kinda egg shapped and not true round shapped, I was wondering if this would be big enough to pick up regular non dish network satellites with using the correct standard feedhorn? Now my next question would be how would i retrofit the feed arm to accept a standard KU band LNBF?
Thanks for any and all advice...
Read this:
http://www.satelliteguys.us/fta-mpeg2-faqs/34131-what-can-i-get-18-dish-dish-500-a.html
With that dish 500 You'd be wasting your time if you wanted any kind of reliable FTA with a linear LNB. Once you get a linear LNB on there you will only get the strongest of the strong, and that isn't much. 3 channels, location and weather dependent.
I did this when I first got my Coolsat 5000:
SatelliteGuys.US - meinename's Album: Dish 500 for 123W
Wait, are you talking about the 26"Hx24"W on the non-skewable polar mount?
A Dish 500 is 20" so yours sounds like a slightly bigger one. Superdish maybe, or is that one bigger than 24 inches? I only have some extra 18 inchers and 500's laying around, so I'm not sure what size a Superdish is.
If he has the one I think he has...
I picked one up for fun from a neighbor last December.
It's a d-tube polar mount that's non-skewable. Imprint indicates that they use the same polar mount for a Dish 300 and this dish with a larger reflector. Reflector measures 24 inches wide by 26 inches tall.
Pics attached.
It's pointed at 119W and I added 110W yesterday to watch Pirate TV ITC for kicks. My LOS is frustratingly split here...:mad:
DN was using them here for the HD stuff on 129W before C2.
Any ways this is the dish that I used for 97W when I was reviewing out the DVR-1100c. I got about half of the transponders. I remember watching MHz Worldwide, Russia Today (borderline), Press TV, and listening to American Liberty Radio. My Coolsat hardly had a day that it would work except for MHz Worldwide.
For the linear lnb bracket I used the one I got with my red Techsat Tracker II+
Took some messing with screws, nuts and washers to get something to get it to stay but I had it working for over a month semi-reliably. A good rain cloud and I lost most everything on it 'til it passed.
Got the bracket from here:
http://hypermegasat.com/Package Deals.html
http://hypermegasat.com/Accessories.htm#universal brack
Thanks Everyone, it sounds like it basically would not be worth my time to mess with it then. It was given to me and i though just maybe i could use it for a fixed dish but sounds like it is still too small for the real satelites out there will work best with the kindergarden sats for E* and DN
Bobby
You will need a minimum of 30"+ dish to get FTA on KU.
The 24" dish you are talking about is usually used for 129 echostar satellite as a wing dish because that orbital location has a weaker signal.
Quality Signal bar jumps from 0-62 %
NASA Shuttle broadcasting on 83.0°W
