Openbox s9 open box help.
$835.00
satmex
7
Santa Clarita Ca
I have a new s9 open box that I never got to set up and the problem is that the satellite list I don't see
97w (G19) or 125w (G14) the list only shows telestar 12 (orion2) 15 west the others are east I can't see this satellites from my location, I'm at lat 34.4476 long -118.667 how can I change this list? any up dates that I can use to change list. thanks in advance.
satmex.
You can rename them, and change their location *Safest solution* OR:
First - make a backup of your TP_Prog.dbs then on your computer rename it ORIG_TP_Prog.dbs
Then copy this American List TP_Prog.dbs (Unzip it first) to the stick and upload it to the receiver.
Think it's the list I used, otherwise, why did I save it ???? *Unsure if it's compatible with all FW versions.
you can edit the list with the remote using the various colored buttons.
From the amount of programming left it wouldn't take long.
I do that with euro firmware I play with,I just edit in 72w.
Thanks guys I will do the easiest way possible. I will post later when I get it to work, cheers.
AMIKO Amiko HD SE- Channel Information
GEOSATpro Flashing Video - C and ku
