I knew those statistics classes I had to take in college would come in handy some day.
Looks like both polls are running about the same.
Makes you wonder if the Dish folks are looking at these polls too.
AT this point DISH needs to do something to compete with DIRECTV and if that means hd lite and putting more hd channels on one transponder , I think that they will do it. And when they do relaunch DISH in full mpeg 4 we will get full resolution on all hd once again. I know I wouldn't mind having some of those same hd channels that DIRECTv has today. IT would only be hd lite for about 6 months and then we would go back to full resolution.
Maybe DIGI should run a poll on whether DISH subs would accept hd lite and gain all those hd channels that DIRECTV has or wait till next summer to get them.
You guys are still operating under the fantasy that you can see differences in HD resolution, and the false premise that differences in clarity are due to resolution, rather than bitrate.AT this point DISH needs to do something to compete with DIRECTV and if that means hd lite and putting more hd channels on one transponder , I think that they will do it. And when they do relaunch DISH in full mpeg 4 we will get full resolution on all hd once again.
I would post the chart again, that shows that the human eye in the average living room cannot physically tell the difference between 720p and anything greater (let alone the difference between 1440x1080 and 1920x1080), but I won't bother since you clearly want to believe that you see the difference.
The original myth of "HD-Lite" came out because D* was lowering both the bitrate and resolution below what their encoders required to produce good PQ. The reality of lossey digital video (i.e. DBS and DVD) is that the numbers are whatever the encoders require to produce good PQ. No particular number has a meaning separate from the material.
The "Fish Tank" and the "Yule Log" can look really great with bitrates far less than what is required for Star Wars III.
To summarize, If the poll shows that no one notices a difference, then it is NOT HD-Lite.
I didn't mean to rattle your cage about hdlite vs full hd. I only meant that in order for DISH to compete and add more hd NOW vs the future to compete with DIRECTV , that they could add more hd channels per transponder and reduce the bit rate or the resolution or what ever it takes to produce more hd channels. This might reduce the pq a bit for some who say that they can see a difference in pq. I don't know that much about the differences between bit rate, resolution etc. I was pointing out that it might be needed to reduce it now to have more hd channels now and in the future they would take it back to what it is supposed to be , when they relaunch DISH in full mpeg 4. I use the term resolution to refer to pq as I really don't know what else to call it.
My main point is what ever it takes for DISH to put up more hd channels , they should do and the effect on pq will be temporary till the new sats are up and running. So in 6 months we should have more hd and in better pq , resolution,or bitrate or what ever you want to call it.
What new encoders are you guys talking about?
Aren't they testing 7 hd channels on one tp with new encoders?
So let me understand, D* gets ripped a new a**hole because they had to use HD Lite in order to get channels on their existing satellites until their new satellites went operational. But now that E*'s in the same boat it's now going to be OK to use HD Lite?![]()
Your act is getting old Rad. Your blanket generalizations are so weak they fail to find any mark. Why not try a new approach and limit your posting to forums for services that you actually subscribe to? <not holding breath>
NightRyder
Because of the hypocrisy of the E* folks that ragged D* whenever they had the chance when they were in the bandwidth crunch and now saying it will be OK to do the same thing. Because of al the E* folks that said no way in hell would there be as many HD channels up by the end of 2007 for D* to send out and they were saying. Because of all the bind following that a lot of E* folks are showing, when they used to tell D* folks to come to E* for all the HD we have now, forget promises, now they're looking from promises from E* for what the might get.
rad, rad ,rad. 99% on here do not care if Direct has a bigger penis. Us dish subs just want more hd.![]()
