Satmex 5 Help
its not scrambled. Should log in as the actual channel name (some channels log in as TV1 or SNG but this is the actual name)
what is your signal quality on it?
the signal strength stays at 70 or so for a few seconds then it goes down to zero then back up. like it resets. but signal strength on the install menu is constant.
signal strength or quality?
strength doenst mean much...just the the LNB has power
quality is what you need
if it was used to steal beforehand, then yes I have seen that happen
Might want to flash the software back to legit status.
captiveworksusa.com has the software
I think so. It bought it for 30 dollars. It does have something in settings saying dish/beav or something like that. I'm at work so can't check for correct spelling on some of the options. If I do need to reflash. How do I go abouts doing so. Thanks so much for helping me.
I would like to get the others and the radio. Guess I'll have to get a better signal and rescan. But I got what I really wanted to get. Thanks so much again. Next project is another fta with motorized. That should be fun setting up.
The radio station on that channel is on a 2nd audio. Hit "audio" or "language" on the remote and it should show a 2nd audio stream. Thats the radio
Miniumum ku dish size NBCHD on AMC1?
Conical Scalar Ring Test Results
