VIP 722 installation problem
alaskaman
7
Received from Dish network a new HD VIP 722 to replace an old SD 512 but it won't receive.
Do I need a different LNB? If so what's a good brand and model?
More details about "won't receive", please? Are you getting a particular error code?
When you get a new receiver, you have to run the installation wizard. Even after that, if having problems, go to Menu-6-1-3 and tell us what sats are on line G, and after it completes, what color is under each number. Also, what does like H say for "Device"?
When you go from a SD receiver to an HD receiver you also need to swap out the dish antenna. Why were you not offered an upgrade promotion?
Yea, I don't have any additional questions. Normally shipped receivers come with instructions at least.
AK/HI only use 110/119 for SD and HD
Sent from my iPhone 4S using Forum Runner
I'm in rural(bush) Alaska with no local techs or installers, so this is a do it yourself installation as usual. Since I posted last, called a Dish retailer about 400 miles from here and they mailed me a couple new high def LNB's. Can tell there is going to be a problem getting the new skinny throated LNB to fit into the mount at the end of my 4 foot dish. Hope it can be shimmed with electrical tape, but it'll be my luck will have to order a smaller diameter holding bracket. Plus it's below freezing up here today which is going to make climbing on my roof an adventure. Might have to wait a while to prevent playing slip&slid up there.
hopper transfers app?
Dish transfer app has disappeared
