Well that's pretty slick...I haven't tore into one to have a look but what he did was he is now powering the 13 volt side with the bias voltage meant for the 15 volt regulator which is probably coming from the 18 volt reg on the other side. The only thing that would concern me would be some possible added crosstalk between ports. Fire in the hole...I have run the trace as best I can so that other can follow what he did.
Well I don't understand most of what he says, but from what I did understand, he only removed or by-passed the parts that brought the voltage down to 13V. The circuitry was all there and is still there for everything else.Well that's pretty slick...I haven't tore into one to have a look but what he did was he is now powering the 13 volt side with the bias voltage meant for the 15 volt regulator which is probably coming from the 18 volt reg on the other side. The only thing that would concern me would be some possible added crosstalk between ports. Fire in the hole...
The devices that I am using are not switches. I don't know what you might call them except maybe LNB power boosters. See this link from where I talked about them before.Since these switches will be dedicated to the task, modifying them is just fine.
Of course, you cannot ever replace them with stock switches, so just keep that in mind.
This switch has an external 24 volt power supply?
I think that's a plus for this operation.
That's basically all he did.Looks like he just bypassed the 13V regulator.
